Old 04-02-2014, 10:19 AM   #1
Trey T's Avatar
Sounds like the AOS
1. Change out the AOS and make sure to buy the most updated AOS.
2. Check oil level. If your dash says low, shut it off.
3. Inspect the squeal; open the engine covers (in cabin and under clamshell conver. top). The squeal could be something simple like belt, roller, etc...
Trey T is offline   Reply With Quote
Old 04-02-2014, 10:38 AM   #2
Registered Boxster abuser
healthservices's Avatar
The squeal could be the AOS itself, basically a broken diaphragm that is now making noise since air and oil is being sucked into the intake track.
