Old 03-15-2014, 03:54 PM   #1
2003 Boxster S Aero/Sport
Clunk
I am hearing a "clunking" noise coming from under my Boxt. Especially at slow speed, such as right after I back out of the driveway and take off for the day. I heard it once a couple of weeks ago, then not since. Now it's back. Not a good sound. Clunk, clunk clunk.
Sounds like a trip to the mechanic is in order.
2003 Boxster S
2007 Jeep Grand Cherokee 3.0 CRD (Mercedes Diesel)
2013 Audi Q3 (wife's car)
mistergreen is offline   Reply With Quote
Old 03-15-2014, 04:15 PM   #2
too early
could be motor mount , trailing arm.... does it occur any other time?
nicecar is offline   Reply With Quote
Old 03-15-2014, 04:23 PM   #3
Typically only when driving slow, it seems. And seems to happen when my wife is in the car, reinforcing her notion that "that car is going to be a money pit"!
My concern of course is that it won't do it for the mechanics.
2003 Boxster S
Old 03-15-2014, 04:30 PM   #4
yes she is right....however pick up a wrench if you can.. you will save a ton. If its behind passenger seat my GUESS is lower trailing arm. That was my first fix. search on this forum... you will find it. Probably went away when cold. Good luck. How many miles on this car?
Old 03-15-2014, 04:30 PM   #5
Beginner
Jamesp's Avatar
Is it "clunk, clunk, clunk" as you're backing up, or a single "clunk" as you leave the driveway?
2003 S manual
Old 03-15-2014, 05:14 PM   #6
Steve Tinker's Avatar
I would inspect your driveshaft securing bolts to see they are not loose or missing......
Loos driveshafts make a definate clunk when changing direction and / or going from reverse to forward motion and vice versa.
2001 MV Agusta F4.
Old 03-15-2014, 06:21 PM   #7
Beginner
Jamesp's Avatar
I wouldn't worry too much about drive shaft bolts. Axle bolts, perhaps, CV joints, a possibility, suspension parts, maybe. How the "clunk" presents itself will be telling. Rhythmic / going from reverse to forward gears points to rotating parts, over bumps points to suspension.
2003 S manual
Old 03-15-2014, 07:22 PM   #8
It seems to be moving forward, and yes, over bumps it's worse. I'm guessing suspension.
85K miles.
2003 Boxster S
Old 03-17-2014, 06:17 PM   #9
Let me know what you figure out. I'm in Houston as well. I have a similar noise. Maybe a joint strike?
My attempt at a car blog - http://txags986.blogspot.com/
2004 Boxster S Anniversary Edition #1540 - My daily driver
2012 Mini Countryman S - Her daily driver
1966 Ford Mustang - Son's daily driver in 2026
TxAgs986 is offline   Reply With Quote
Old 03-29-2014, 06:56 PM   #10
Heading to the shop on Monday to have them check it out. Will let you know.
2003 Boxster S
Old 04-12-2014, 02:32 PM   #11
They couldn't find a thing. All looks good up there. So, don't worry, be happy, and leave the top down!
2003 Boxster S
Old 04-12-2014, 06:45 PM   #12
Jager's Avatar
You will not find this issue with a visual inspection... Here is where the noise was coming from when I had the same problem (see attached picture), you will need to replace the the control arm links.
Pelican Parts - Product Information: 986-331-043-07-M80
Jäger
300K Mile Club
