Old 04-26-2014, 12:18 PM   #1
dumb question, but i just need to put car in neutral for that correct?
stateofidleness is offline   Reply With Quote
Old 04-26-2014, 12:21 PM   #2
Registered Boxster abuser
healthservices's Avatar
block the wheels if the car is in neutral and parking brake off.
Old 04-26-2014, 12:20 PM   #3
spray the outside of the cv boots with some wd40 and if it happens with suspension movement poke a pin hole in the lower ball joint boot and spray wd40 in there.
Please note this is for diagnoses only as the lube will disappear and the sound will come back
