Old 03-09-2014, 05:16 PM   #21
Originally Posted by smshirk View Post
Jim fixed mine too. Jakes motor was too much for it. Jim also rebuilt my 968 6 speed a few years ago. I head the dreaded pinion bearing problem, but he went through the whole thing replacing just the parts that were worn. The difference in the way that car runs is amazing. That was an expensive job but it took a lot of time.
Jake recommended this shop based on I believe your past history and good results so thank you for that ! Jim's a good guy just like Jake, we are fortunate to have both of them in our backyards.
rfuerst911sc is online now   Reply With Quote
Old 03-10-2014, 02:22 PM   #22
Engine Surgeon
Jim did a great job on both smshirk's tranny as well as this one.. I was impressed with the positive engagement and ease of shifting.
US Patent 8,992,089 &
US Patent 9,416,697
Old 03-11-2014, 12:17 AM   #23
so far my neck surgery seems to have worked. I have a right arm again. I'm not supposed to be driving until after 3/19 when I go back to doc, but i couldn't help myself. No problem at all driving and once i finish PT I think I'll have complete range of motion back. I can raise the arm almost 180 before any PT at all. When I shut either door on my Boxster the Fabspeed pings like a banjo string, only with the car turned off. Doc says its not the neck or the arm! What could it be? Can't be heard with car running, even with the LW flywheel in a box for now.
2001 Boxster S 3.6, 2003 E46 M3, 94 968 Cab, 80 911 Weissach Edition, BMW 1200 CLS
smshirk is offline   Reply With Quote
