Old 02-12-2014, 08:50 AM   #41
03 Base 5 speed, 40k miles, original IMS as far as I know.
2003-09 Original owner, 15k miles, no records.
2010-2012 2nd owner, 19k miles, well documented service, oil changes: Mobil 1 - 0W40
2012-now oil change every year or 5K.
I don't plan on touching the IMS until it needs a clutch, will decide then. For now, I don't worry about it, I just drive.
tomonomics is offline   Reply With Quote
Old 02-12-2014, 01:44 PM   #42
Dlirium's Avatar
2001 S 6-speed manual California car. Converted to spin on oil filter (LN 106-01) at 100k miles. 116k miles, original IMS. Blackstone reports say all is good. Crossing my fingers.
Mobil 1 synthetic 15w50 every 5k miles.
Old 02-14-2014, 10:53 AM   #43
Boxster S Bassist
2000 S with 74K miles. Use synthetic oil changed at 5K miles. Just replaced my IMSB with LN dual row ceramic bearing! My clutch was on the way out anyway... Horrendous cost but the added peace of mind takes some sting out!
John Bergen is offline   Reply With Quote
Old 02-14-2014, 10:58 AM   #44
Boxster S Bassist
I forgot to note that we found minor metal indications in the oil filter. Plus after the IMSB was removed you could feel roughness when rotating it. Thankfully we caught it early!
Old 02-14-2014, 11:16 AM   #45
Perfectlap's Avatar
how many oil changes did the car have under owner #2?
Owner #1's non-existent record would be troubling to me as he was averaging barely 2,500 miles a year. Sounds like annual oil changes at best.
Seems like youre' in that zone of being way too early for clutch #2 while having a car that may have sat for long periods. I would add the LN Guardian or swap bearing #1 for the low cost Pelican IMSB until you do go in for clutch #2. One is nominal cost the other is simply a day at the shop. I'm sure the Pelican bearing can make it to the next the clutch no problem.
Old 02-15-2014, 01:53 AM   #46
Some great high mileage Boxsters here!
Original owner, 02 Base, ~80k miles, Mobil 1 every 7500 miles, tracked ~40x, no specks in oil filter, no retrofit.
02 Boxster (DD sans kids)
08 Corvette Z06 (Track car)
Old 02-15-2014, 05:19 AM   #47
2001 Boxster S, manual transmission, 71,465 miles, Castrol 10w-40 Syntec; originally used Mobil One for the first few changes. Bought the car with 19K miles---I'm assuming I'm still on the original IMS.
Old 02-15-2014, 07:52 AM   #48
Is this still an issue or have most of these cars now been updated?
VWAudiChris is offline   Reply With Quote
Old 02-15-2014, 08:16 AM   #49
BIGJake111's Avatar
most cars are on original... do not let the IMS worry you away from these cars. If it happens it usually happened early on in the cars life. Just make sure to check your oil filter for metal shavings when you do oil changes. Best way to prevent an IMSB going out is to drive the car like a Porsche needs to be driven. The 90s cars are less likely to fail though.
Old 02-16-2014, 10:39 PM   #50
Idaho Red Rocket 3's Avatar
2000 S Second owner since 48k miles. Currently 85K miles on original IMS and RMS. Clutch was replaced at 44K along with AOS. I recently did water pump and front motor mount.
2000 Boxster S
Old 02-18-2014, 08:55 AM   #51
Trey T's Avatar
01 base tip with 70K miles. Still at its infant driving mileage. I hope to get to 200K miles like some of you.
Lube change: semi-annually (every ~5-6K miles)
Lube specs: M1 0w40 or Castrol 5w40, whichever deal I can get for stock-up. I use filters from Hengst, K&N, or Wix .... whichever deal I can get for stock-up.
Trey T is offline   Reply With Quote
Old 02-18-2014, 10:39 AM   #52
Perfectlap's Avatar
I've heard conflicting conclustions about when the IMS bearing is most likely to fail. It seems to me that there are various conditions under which an IMS can fail. Some are low mileage with infrequent oil changes. Some are high mileage with infrequent oil changes.
If there is in fact contamination from not changing the oil enough, we may be entering a period where a large number of the Boxster/996 fleet that did not have their IMS bearings swapped when the clutches were replaced, and were looked after in a suboptimal way up to this point, could be finding out the hard way that a bearing can only last a long time if you looked after it correctly. We have no way of knowing if current owners have been diligent. In the past it didn't matter as much because in most cases, a fresh bearing can withstand abuse up to a certain amount of mileage. But what happens when you go beyond that? As a group, Boxsters and 996's are only now going past moderate mileage.
If the typical old German and British car ownership experience bears out, most owners are not as diligent as they should be, and in this case we're talking about a very large number of Porsches rolling around. It seems to me that a person of modest means is going to dump one of these cars before investing in a comprehensive IMS swap. Whereas neglect in the past could result in a poor running vehicle, in this instance prolonged neglect can be much worse than that.
Point is, the past is not indicative of what the long-term will bring to these engines. That depends on the owner, and that's not a static input.
Old 02-18-2014, 03:17 PM   #53
Joe B's Avatar
2003 S, 6 speed manual transmission, 92,000 miles, Joe Gibbs 5W40 oil changed every 5,000 miles.
Old 02-18-2014, 06:01 PM   #54
This poll has over 40k views and less than six reported a failure.... whether true or not. This is more or less in range with the figure a senior Porsche exec would throw at you when asked lol
moving parts huh, fun fun
The thread has over 40k views but the poll closed long before then. You have to look at the total votes on the poll before it closed, since there were options for both "yes" and "no". Out of 64 voters, there were 6 failures, or just a little over 9% of the respondents. This is in line with the ~8% failure rate Porsche quoted during their recent class action settlement.
desert_porsche is offline   Reply With Quote
Old 02-20-2014, 06:20 PM   #55
jcb986's Avatar
2000S, 3.2 liter, 78,600 miles.:dance:
Old Hippie Young Heart
