02-05-2014, 06:43 AM
#21
^ benefit of that magnetic drain plug
2004 Boxster S
02-05-2014, 06:46 AM
#22
I never thought about draining via the filler tube
Seal Grey
02-05-2014, 07:23 AM
#23
Wow nice lift. I see you got a couple of extra bolts that your not using too.
Is that the Max Jax?
02-05-2014, 09:38 AM
#24
02-05-2014, 10:12 AM
#25
I guess one disadvantage of the spin on filters is that they are more work to cut apart and look for metal debris.
Chris
'86 944, manual steering, a/c delete, 944Max chip
'87 951, K27, LBE, Turbo S brakes, Koni Yellows, Weltmeister sway bars / strut brace, LSD, full cage, OMP race seats
'01 Boxster - Seal Grey / Black / Black, Litronics upgrade / de-ambered
02-05-2014, 12:38 PM
#26
Originally Posted by woodsman
also be ready for 8.75 L or about 9 qt to flow out
The oil filter is higher than the sump. All you'll get is about 1/2 quart that is contained within the filter, the remaining 8-9 qt will stay in the sump.
02-05-2014, 12:55 PM
#27
Not when you have the correct tools:
02-05-2014, 08:32 PM
#28
LOL, yes good eye.. Although some bolts are missing I used crazy glue to keep it in place! (:
It is a Max Jax, awesome. With a chair creeper it lifts to the perfect height. I have a new concrete pad being poured outside my work shop and that will be it's new home. Between the 10 bolts I had 2 that didn't fit- the guy who set the wedge-it anchors kinda messed up. Max Jax has a video using just 1 arm with only 3 anchors and it lifted 3000 lbs... So I figured for an oil change I'd live on the edge a bit.
2004 Boxster S
02-06-2014, 06:22 AM
#29
Very cool - never seen one of those before. I guess you could make one pretty easily from an old tubing cutter.
'99 black 986
02-06-2014, 08:02 AM
#30
So much for a quick question about oil filters! OP might has well asked "What oil should I use?"
02-06-2014, 10:43 AM
#31
Ok, so I finally looked at this thread on a desktop - and NOW I understand what everyone is talking about with the oil filling from upside down.. I posted the picture and viewed the thread on an iOS device - it shows the photo right side up!
2004 Boxster S
02-06-2014, 11:54 AM
#32
Too funny! I was trying to add pictures to a VRBO property last night and the same thing happend...it was fine on my laptop desktop but inverted when I uploaded the pic to VRBO!
02-06-2014, 12:07 PM
#33
Been wanting to visit FL, count me in! (:
2004 Boxster S
