02-03-2014, 10:55 AM
I am my own mechanic....
OMERGAWDWTFBBQ??? Another code??
P0456, some vaporizing system has a "very small leak" and feels justified in sticking me with a CEL, days after semi-major surgery. Some cars, you just can't please.
Any places to start? I have a new gas cap, but saw in searches this can be anywhere along the gas tank evap or vent system?
'08 VW Touareg T-3 wife's car
02-03-2014, 11:48 AM
P0456 is usually in the EVAP system components.
02-04-2014, 09:30 AM
I'd like to know where/when you heard WTFBBQ
The engineering kids I worked with at Cal Poly Pomona used it on a flyer for a party back in 2008 or so. Just curious where you heard it first
02-04-2014, 12:15 PM
I joined a firearms website and got involved in their GD section in 2008, and man do they throw out the memes and acronyms like that.
It's the trash can of the internet, but with rules.
AR15.com
02-04-2014, 01:21 PM
Registered Boxster abuser
One of the best ways, actually about the only way unless you just want to replace parts until you are blue in the face  is a smoke machine.
This tool is not cheap but well worth it if you are a tech.
otherwise I would start with the solenoids for the evap system, they sometimes stick open and checking that none of the vacuum hoses broke and fell off
02-04-2014, 01:31 PM
Beginner
Start at the scene of the surgery and any lines or components that may have been inadvertently disturbed. What could have been bumped into, pried on, or otherwise folded, spindled or mutilated during the surgery?
2003 S manual
02-04-2014, 01:39 PM
It was water pump and low temp stat, and coolant flush. Not much to disturb down there.
I did read about a smoke machine. If I can slightly pressurize the system I do have a combustible gas detector / sniffer.
May be time to search for and buy a Durametric.
02-04-2014, 04:22 PM
Beginner
The only thing even remotely close is the vac line running down the firewall on the left side. It should be pretty robust, but if it were bumped into it might disconnect. you can look right at it with the left rear wheel off. it is just above the plastic under car close out panel on the firewall. Unlikely, but that's all I got.
2003 S manual
