Old 01-21-2014, 02:34 PM   #1
Perfectlap's Avatar
Those of you with spacers on 10" wheels
Do you get a shimmy at all at around 65 mph?
p.s.
Here's a random 981 Targa pic
Old 01-21-2014, 02:39 PM   #2
golonaus's Avatar
No problem here with 17mm spacers
Wheels unbalanced?
99' with 3.4l engine. ROW tune. SAI delete
Old 01-21-2014, 03:00 PM   #3
Perfectlap's Avatar
Wheels unbalanced?
They were balanced, in fact one is brand new so it was balanced for the first time.
You have 18x10's?
Old 01-21-2014, 03:15 PM   #4
Steve Tinker's Avatar
p.s.
I see Porsche have recently downsized the brake rotors and calipers on their latest offerings !!
Can't say its a particularly appealing look though.......
2001 MV Agusta F4.
Old 01-21-2014, 04:13 PM   #5
murphy986's Avatar
I've got same size. No shimmy here. Is it possible to get warp on spacer from cold to hot temp change down there? Kinda like the opposite of taking a hot pan off the stove and running it under cold water...??? Just a guess.
Novice
murphy986 is offline   Reply With Quote
Old 01-21-2014, 04:35 PM   #6
golonaus's Avatar
You have 18x10's?
18x10 carrera wheels. ET65
Old 01-21-2014, 06:39 PM   #7
Joe B's Avatar
(Wrong quote)
Old 01-21-2014, 06:40 PM   #8
Joe B's Avatar
[QUOTE=Perfectlap;382243]Do you get a shimmy at all at around 65 mph?
No.
Old 01-22-2014, 03:03 AM   #9
EssexPorsche's Avatar
PL,
Hope you are well, i haven't posted for some time.
What width spacer are you running?
EP
Don't care......was made to care! (my Mum)
EssexPorsche is offline   Reply With Quote
Old 01-22-2014, 03:17 AM   #10
Rennzenn
j.fro's Avatar
I've got 18x10 rears w/7mm spacers. As long as the tires are balanced and not flat-spotted, things are very smooth at all speeds.
Old 01-22-2014, 04:41 AM   #11
billj18's Avatar
My wheels are not nearly as big, but I had a similar problem when I put 15mm spacers on my 17" Sport Classics. It seems that the hub, spacer, and wheel mounting surfaces must be scrupulously clean. The smallest bit of dirt or rust keeps everything from bolting down tight and parallel, causing vibration. I had to wire brush the hub surface and the back of my wheels to clean everything up. Of course, mine is my daily driver, so it's exposed to the elements. YMMV.
Tip: be sure to put a thin coat of anti-seize between the aluminum spacer and the steel hub, or else they will weld themselves together.
Bill
BJ's BlackBox -- 2001 Boxster
1997 SAAB 900S Turbo
1980 Maxda RX-7
1974 Fiat 124 Spider
1976 Datsun 260Z
billj18 is offline   Reply With Quote
Old 01-22-2014, 12:24 PM   #12
BruceH's Avatar
None for me.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 01-22-2014, 12:57 PM   #13
Perfectlap's Avatar
Originally Posted by EssexPorsche View Post
PL,
EP
Happy New Year sir.
I checked the invoice and it's not listed. Obviously they're on the car now but judging by my Google Images search they are at least 15mm. Heavy...
