Old 01-20-2014, 10:30 PM   #1
o2 sensors
Hey folks,
anyone know which site has the best price for O2 sensors for the 986 boxster base (2001)?
It seems its quite expensive at pelican.
BTfd2e93 is offline   Reply With Quote
Old 01-21-2014, 05:20 AM   #2
steved0x's Avatar
Amazon Get the part numbers from Mike Focke's Boxster pages and then get from Amazon.
https://sites.google.com/site/mikefocke2/oxygensensors
You have a 2001 so your numbers are:
15182 Oxygen Sensor - OE Type Before Catalyst (Front)
15183 Oxygen Sensor - OE Type After Catalyst (Rear)
If you enter these numbers into Amazon search it will take you right to them. I myself has installed the 15183 just a few weeks ago and it is working like a champ (into a 2000 S)
Steve
Edit: it looks like there is now a generic "exact fit" style aftermarket sensor on there that doesn't require splicing for around $30... Most folks have not had luck with the splicing type aftermarket sensors but this one is no splice.... if it was me I would probably still get the Bosch but Amazon has a really great return policy if you wanted to try those others....
Old 01-21-2014, 09:10 AM   #3
thanks mate. the wealth of information available on this forum simply blows my mind.
Thanks again .... i just ordered 2 x front + 2 x rear o2 sensors .... must have saved like 200$ off .. as compared to getting them from pelican.
Old 01-21-2014, 11:25 AM   #4
Why are you replacing the O2s? Many people needlessly replace them because they mis-interpret fault codes.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 01-21-2014, 06:19 PM   #5
good question! @ san rensho
i got O2 sensor malfunction codes on my car recently.
since its expensive & not readily available in HK (where im located) .... i decided to get them first.
any other smoking gun symptoms I should be looking out for?
Old 01-22-2014, 07:55 AM   #6
What codes? Many people misread codes and conclude they need to replace expensive parts unnecessarily..............
Old 01-22-2014, 06:25 AM   #7
More than one sensor going at a time is highly unlikely (unless getting fouled by something upstream).
The fault codes associated w/ O2 sensors don't mean sensor is bad but rather the value being reported by them is outside of spec. Sure it could me sensor itself is bad but more than likely it means there is another problem up stream... and doubly so when more than one goes at a time.
What codes are you getting? And more importantly, what work was recently done?
With a multi-meter you can easily test each sensor to see if it's truly dead.
Good luck
Old 01-22-2014, 07:58 AM   #8
The reading I got was no signal detected from the o2 sensor on bank one.
I forgot the actual obd code. Since it said no signal detected I assumed the sensor itself was faulty.
As i understand it should be in a constant state of fluctuation rather than flat 0?
Maybe I jumped the gun on this one.
2 months ago I had the tranny out Co's the seal / ring right at the from of the gearbox (I don't know the official part name) broke.
I guess it's possible when the cats and exhaust was taken off ...something might have gotten loose.
Old 01-22-2014, 08:37 AM   #9
Bad assumption, it could easily be a wiring problem left over from the previous work. You need to check voltages and harness continuity for both the sensor and its heater before even thinking about replacing them. I'd bet there is nothing wrong with the ones in the car...............
Old 01-22-2014, 05:07 PM   #10
thanks folks.
i guess i have a set as spare ... itll be worth it cos i wont have to dig around and wait (for a week shipping) for them when i do finally need them!
i reset the logged code, and it didnt come back. Im going to monitor it a couple more days. I'll also check the voltages & connections next week when I install my new fabspeed exhaust ... cant wait!
