Old 02-09-2006, 10:27 AM   #1
Grinding noise from steering wheel
Has any one else experienced this? I have noticed a grinding noise whenever I turn my steering wheel on '01 Boxster w/35K miles.
I know that my 540i had a issue with the slip ring on the steering wheel that used to cause a similar noise and went away after replacement. Is this also common on the Boxster? Would this be a warranty issue?
bimmerbat is offline   Reply With Quote
Old 02-09-2006, 11:52 AM   #2
Have you had your Wheel and Column Switch off? Or has there been any worked performed which would require the Wheel or Column Switch's removal?
There is a specified Gap between the very Tip of the Steering Column and the Sheet Metal Face of the Column Switch which must be maintained. This Gap is 55±0.5mm or 2.16±0.02 in. Without this Gap, the Wheel will make the sound you describe. Hope this helps...
Happy Motoring!... Jim'99
