Old 01-08-2014, 03:36 AM   #1
error codes - important or not ?
Hi - I currently have two error codes on my 2001 Boxster and wanted to know in simple terms what they mean and is it necessary to have the car "fixed" - also if anyone knows what the "fix" procedure is.
the codes are P1128 Oxygen sensing adaptation area (cylinders 1-3) rich
P1130 Oxygen sensing adaptation area (cylinders 4-6) rich
Thanks for any help
rossa123 is offline   Reply With Quote
Old 01-08-2014, 04:33 AM   #2
fullthrottle52's Avatar
Thanks for any help
Do a search and you will see many threads on these error codes. Yes, you should have these codes/problems looked at and resolved.
2000 Boxster - Loved and sold
1999 911 Cabriolet - Also loved and sold.
fullthrottle52 is offline   Reply With Quote
Old 01-08-2014, 06:10 AM   #3
kk2002s's Avatar
Yes you need to address. I suspect there can be a variety of issues that generate these.
For me it was a vacuum leak between AOS and Throttle body.
I'm thinking because both generate it is a central issue before a specific Bank but after the MAF
The o2 sensors after the MAF and what the MAF is reading are out of sync (Potentially a vacuum leak introducing intake air after the MAF)
Could be the MAF as well
Seal Grey
Old 01-08-2014, 06:58 AM   #4
Topless's Avatar
Your car is running lean and this may damage the engine over time which can get very expensive. As said earlier, the most common causes are a failed MAF or intake air leak. Time to dig in and do some diagnostic work to find the problem. Lots of threads on these codes as it is a fairly common problem on a 10+ yr old car.
Old 01-08-2014, 11:40 AM   #5
haz
haz's Avatar
Let your local Porsche Center / Indy shop diagnose the car and have it fixed. There is no other option if you want to take care of your car. You should not have it "fixed", you have to get it fixed. K?
haz is offline   Reply With Quote
Old 01-08-2014, 03:30 PM   #6
Hook it up to a Durametric (or possibly other readers.) If the MAF reading is significantly below 15 kg/hr, then almost positive its a vacuum leak. Another cause of vacuum leaks is a fault in the evap system (something I am chasing down now) or a broken oil filler tube.
If the MAF readings are near 15, then it could be a bad MAF sensor, or fuel delivery problems, e.g. fuel pump, pressure regulator etc.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
