Old 02-06-2006, 05:12 PM   #1
Door plugs
If I were to install doorplugs on my Boxster would it affect it in any way? I know that if you leave you Boxster sitting for 5 days you will manually need to unlock it with a key. If I drive my car on a day to day basis there should no such thing to worry about correct?
Old 02-06-2006, 05:23 PM   #2
deliriousga's Avatar
There shouldn't be any problems with that. The only time I've ever used my key to get in the door was when the key head remote was messed up and would not work. My wife has never used the key to unlock the door.
1966 Wife White/Brown Top
Old 02-06-2006, 05:23 PM   #3
Rail26's Avatar
I have let my car sit for 3 weeks straight and I just hit the key to open it. Why would you have to use the key to open it?
5 spd, 18" wheels
AH-64 Apache
RC-12 Guardrail
RC-7 Crazy Hawk
Rail26 is offline   Reply With Quote
Old 02-06-2006, 08:14 PM   #4
I can't speak for the '05 but on the '99 the remote is disabled after 3 days of non-use. The door plugs I've seen are removeable if needed. No worries!
denverpete is offline   Reply With Quote
Old 02-06-2006, 09:28 PM   #5
The door plugs don't work well on the 987, by the way. Our lock cylinder isn't recessed into the handle, so it sits there like a bottle cap. Also, the bumperplugs guys don't seem to have thought about making one that covers the 987 cylinder very well, or maybe it's always been lacking in coverage on the 986 too--it leaves a lot of silver showing.
2005 Seal Grey Boxster S
987 Amberectomy
eslai is offline   Reply With Quote
Old 02-07-2006, 04:30 AM   #6
tqtran's Avatar
blinkwatt : Since you have a 986, the door plug will work fine for you. I have one and it will cause you no problems. It is also very easy to remove when you let you car sit for an extended period of time.
tqtran is offline   Reply With Quote
Old 02-07-2006, 06:00 AM   #7
bmussatti
Posts: n/a
Rail26...this is good news! I thought the car went into "sleep mode" (cee est ta!)requiring the key to open the car. Is this only on the 986?? Anyone? Buehler?
Old 02-07-2006, 06:15 AM   #8
If you do not use the Transmitter on the Key, for approx. 120 Hrs. (5 Days), the Alarm system in the Car effectively stops Listening for it.
The Car does not know when you are going to use your Key Transmitter, and so must remain ON and Listen for it. This puts an excessive Drain on the Battery. To avoid this it shuts down this circuitry once 120 Hrs. have passed. You can reactivate this Feature by inserting the Key in the Lock and Manually unlocking it once.
Anyone stating the time interval is different than 5 Days (approx. 120 Hrs.) is mistaken and possibly confused - it states this right in the Owners Manual. Hope this helps...
Happy Motoring!... Jim'99
