Old 02-06-2006, 04:40 PM   #1
Send a message via AIM to blinkwatt
Rear Speaker Kit
Is this the best price for the rear speaker kit around?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=8032959100&sspagename=STRK%3AMEWA%3AIT
If I order through eBay there is also no tax. So $198 for a shipped NEW OEM Speaker Kit sounds good enough. Anyone know of a better deal?
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 02-06-2006, 06:18 PM   #2
Hi,
That's one of the best prices I have seen. A couple of tips... make sure you have a Dremel with a cut-off wheel to cut out the storage bins on the Rear Box, also, a Hot Glue Gun to attach the speakers.
Also, the speakers size is so restricted, that they're not the world's greatest - that's OK, you're in a Convertible. But, you can improve them greatly by adding some Batting behind them, the Storage Box has some cutouts which are ideal. I used Spun Polyester which I got from a PetSmart for $2 (They sell it as Bulk Aquarium Filter Media).
Adding Batting has the same effect as using a bigger enclosure. I stuffed the Batting in behind the speakers and then Hot-glued some 20 mil Plastic sheeting to enclose them, keeps any bugs or moisture out. This makes them sound as good as they can be for just a simple extra step. I'm attaching a pic (from the World's Worst DigiCam) to give you an idea of what I'm talking about. Good Luck!...
Happy Motoring!... Jim'99
Old 02-06-2006, 06:32 PM   #3
donv's Avatar
Just a caution from hard-won experience... hot melt will, well, melt in that location under the window in the sun. At least go for the high temp hot melt if you use it, but I recommend you find another solution unless you want to hot melt the engine cover carpeting...
2001 Lapis/Black/Black, PSM, Rear Speaker Kit, Optima...
donv is offline   Reply With Quote
Old 02-06-2006, 06:54 PM   #4
Hi,
Although I have not experienced what you're talking about, you do make an excellent point.
I guess if I had to do it over again, after reading your post, I'd go with an epoxy rather than the Hot Melt...
