Originally Posted by donv
Just a caution from hard-won experience... hot melt will, well, melt in that location under the window in the sun. At least go for the high temp hot melt if you use it, but I recommend you find another solution unless you want to hot melt the engine cover carpeting...
Hi,
Although I have not experienced what you're talking about, you do make an excellent point.
I guess if I had to do it over again, after reading your post, I'd go with an epoxy rather than the Hot Melt...
Happy Motoring!... Jim'99
