Old 12-20-2013, 02:22 AM   #1
Alarm lights don't flash
Having issues with the alarm. When I arm/disarm the alarm the lights don't flash. All the lights work normally when driving just not with the alarm. I was going to take out the alarm module and see if there's a stuck relay inside but thought I'd ask if anyone has any ideas.
markskyline is offline   Reply With Quote
Old 12-20-2013, 06:41 AM   #2
Scan the alarm function with a PIWIS or Durametric system to see if it is working properly.
Old 12-20-2013, 06:56 AM   #3
steved0x's Avatar
Try setting the alarm with the trunk open or the oddments tray and see if it beeps the horn (letting you know that the car is not secured) Do the doors lock as well?
Old 12-20-2013, 10:06 AM   #4
I do have an open switch somewhere as the horn beeps a bit after i arm the alarm. it locks and unlocks no problem. lights just don't flash.
Old 12-20-2013, 12:51 PM   #5
woodsman's Avatar
that's why they don't flash
Old 12-20-2013, 12:54 PM   #6
Again, scanning the car will tell you where the alarm fault is (the system stores the last ten faults). Fix the problem and the alarm will work again............
