Old 12-20-2013, 09:52 PM   #41
com3dorm3's Avatar
- Sachs Clutch Kit $330.00
- (2) 911 993 Carrera Sport Classic BBS Rear Wheel - 17x9 $500.00
- Power Steering Fluid $15.00
- Wheel Painting supplies $35.00
- (1) Spark Plug Tube, (6) Tube Rings $40.00
- RSS Underdrive Pulley + Belt $210.00
- (2) Power Steering Fluid (2 separate purchases) $30.00
- Aluminum Jack Pads $60.00
- Power Steering Reservoir O-Ring Seals $14.00
- JIC Cross Coil-Overs (Used) $450.00
- Aero Wing - Rear (Used) $130.00
- (12) ACS Race Studs 14X1.5 65mm $62.00
- H&R 30mm Wheel Spacers $160.00
- Auto Paint $38.00
- Inner Tie Rod (Deeza Chassis PO-A601) $24.00
- Porterfield Brake Pads (set) R4 $290.00
- OP Brake Rotors (Front/Rear) $135.00
- Brake Caliper Paint $12.00
- Gas Cap $17.00
- Brake Caliper Decals $16.00
- (3) Motul Brake Fluid $57.00
- TechnoBrace - Rear Cross Member Suspension Brace $104.00
- EBS Oil Sump Baffle $237.00
- (5) Motul 300V 10W-40 2-Liter $145.00
- Red Line Gear Oil 75W-90 $27.00
- Transmission Plug Tool $6.00
- Headlight Bulbs (2) Sylvania H7 $41.00
- Hardtop Spinlocks & Bolts $96.00
- Engine Mount $124.00
- Gauges (Oil Temp and Oil Pressure) $265.00
Total $3720
I hope the list for for 2014 will much shorter containing mostly tires and track fees
2000 Boxster S
com3dorm3 is offline   Reply With Quote
Old 12-21-2013, 02:51 AM   #42
deptotpr's Avatar
My son's 1999 Japanese Mitsubishi Galant with 225,000 - he spent zero (0)
I learned a few Porsches' ago..anyone can afford to buy one, but can you keep it on the road? Yes, it's a sickness...
2013 - $743.66 - not bad........
Oil Change & Filter $217.44 (Dealership)
Both Low Beam Bulb $21.40
Right rear bulb out $2.00
Europlate $69.00
Wiper blades $32.09
Cup Holders replace $50.00
Oil Change & Filter $145.00
Right rear tire $186.73
Headlight restoration $20.00
2012 was $2304.52..(waterpump, fan, thermostat, etc..)
928-to-986-to-996
Tampa Bay, Florida
deptotpr is offline   Reply With Quote
Old 12-21-2013, 04:18 AM   #43
Nimbus117's Avatar
My expenditure is pitiful in comparison (converted to $):
2 x Michelin PS2 rear tyres $450
service $300
replacement reverse camera $15
2003 Boxster 2.7L
2010 Civic Type R
Nimbus117 is offline   Reply With Quote
Old 12-21-2013, 04:59 AM   #44
LN IMSB
RMS
Clutch
Water Pump
Rear wheel bearing
Motor Mount
Regular Service
about $6k IIRC, I really don't want to add it up again, I might just sell the damned thing, since I won't get to drive it much until spring.
Pretty expensive year, and I believe I've got to do the AOS in the spring.
dmairspotter is offline   Reply With Quote
Old 12-21-2013, 06:48 AM   #45
Total for first year of ownership 12/20/12-12/20/13
Starting Milage 96,288 Ending 106,550
Total miles 10,262
Total Cost $1,719
Cost/mile - $0.168
Summary:
2x oil change
1x Gear oil change
Hood/truck shocks, cabin filter
Air filer, serp belt
Plugs, coils
Brake pads, front rotors
Rear tires
AOS
Coolant Cap
Total labor paid $180 (Oil changes, my budget version of a PPI….I)
Not bad for a $7,900 Porsche…..Uh?
runjmc2 is offline   Reply With Quote
Old 12-23-2013, 12:24 PM   #46
woodsman's Avatar
Spent most of spring/ summer with car on jack stands completing work. All parts were OEM unless noted. Total driving was about 11000 KM.
SUSPENSION:
ROW M030 retro kit- $1155 old suspension wasn't worn out yet but it was onsale
rear adj. toe arms 272 (Top Speed)
2 4-wheel align. 267
press wheel bearings 465 only labour at shop this year
4 wheel bearings 260 ( since it's apart...)
T0TAL- $2419
BRAKES:
caliper paint 30
caliper decals 12
GT3 brake ducts 30
bleeder screws 57
stainless flex lines 70
front rotors 354
rear rotors 295
CONTINUED....
Old 12-23-2013, 01:02 PM   #47
woodsman's Avatar
Old 12-24-2013, 01:19 PM   #48
woodsman's Avatar
CONTINUED--
ATS SUPERBLUE $35
emerg. springs 50
Akebono FR pads 106
" RR pads 95
brake lines/ holders 108
caliper bolts
TOTAL $1242
CLUTCH REPAIR, REPAIR:
release bearing $127
2 pilot bearings 40
bolts 30
trans oil 85
assorted parts 220
TOTAL $502
REFINISH WHEELS:
bead blast 1 wheel center $40
spray booth rental 100
refinish supplies 272
mount tires on wheels 75
TOTAL $487
ASSORTED:
Complete cut and polish--
sandpaper, compounds $105
Cat bypass pipes(TOP SPEED) 279
muffler clamps/ bolts 85
hinge repair kit (center console) 29
DRL relay 71
fuel pump/ gasket 565
oil fill hose 40
tensioner pulley 86
engine oil (Motul 8100 20 L) 212
oil filters (2) 32
magnetic drain plug 26
air filter 28
cabin air filter 63
997 short shifter 352
2 Michelin Pilot super sports- Fronts 465
TOTAL $2437
ASSORTED TOOLS:
triple-square socket set
power bleeder
fuel pressure tester
flywheel lock
soft socket
Durametric
remote clamp removal tool
heli- coil kit
APPROX. TOTAL $600
GRAND TOTAL $7687
Old 12-25-2013, 07:57 AM   #49
2005, Tiptronic
Snowman's Avatar
$130 - Two oil changes
$800 - New windshield
Driven about four days a week, plus three trips Austin to Houston. No issues what so ever. Except for that *%$#! rock. ;-)
Snowman is offline   Reply With Quote
Old 12-25-2013, 09:04 AM   #50
2k for IMS upgrade plus RMS seal
200 oil change
Total 2.2k
2003 Boxster S
The French Dude is offline   Reply With Quote
Old 12-25-2013, 01:15 PM   #51
Idaho Red Rocket 3's Avatar
2 Oil Changes $130
1 Trans Oil Change $35
1 Air filter $15
1 Cabin Filter $20
1 Water Pump $130
1 Low Temp Thermostat $60
1 Coolant Change $40
1 Front Motor Mount $115
1 Battery $120
4 Tires $700
1 Wheel Alignment $50
1 Brake Fluid Flush $25
Total $1440
When I first read the OP question my first though was practically nothing. Now that it is laid out, I think I spent a little bit for upkeep and repair.
2000 Boxster S
Old 12-25-2013, 02:52 PM   #52
Only the cost of gas.
2k13 Boxster Amaranth Red/Black
cfos is offline   Reply With Quote
Old 12-25-2013, 03:50 PM   #53
Bfan's Avatar
I think that I am the "Big spender" here so far as my DIY 3.6 rebuild costed me $ 20.917 That's is including used 3.2 engine, VAT, customs, new DIY engine cover, engine mount, and shipping to my country and some performance upgrades to go with it. See my thread on it here
Bfan
There is no replacement for displacement
Bfan is offline   Reply With Quote
Old 01-19-2014, 08:10 AM   #54
I have only owned the car since late September, and here is my list:
Pre-purchase inspection & oil change $465.81
IMS Replacement and all those 'While you are in there' things:
LN Engineering Ceramic Bearing IMS $1,754.59
New Clutch $534.40
New Water Pump, Coolant & Expansion Tank Cap $753.14
Gearbox Shifter Update Kit $360.49
Oil Change $80.00
New Wheels & Tires:
808-Series 18" Wheels from Wheel Dynamics $1,599.00
Michelin Pilot Super Sports $987.03
Mount tires & wheels & 4-wheel alignment $377.80
Double DIN & Amps & Speakers:
Alpine INE-S920HD $530.00
iPhone / iPod cable kit $29.99
Micro Bypass for parking and foot brake $26.98
2 DIN Install Kit $149.00
JL Audio ED 700/5 $380.00
JBL GTO-5EZ Amp $269.95
JBL GTO-504EZ Amp $139.99
AudioControl 2XS (used) $35.00
JBL Xti 5.25" speakers (used) $125.00
Morel Vitrus 402 two-way Component Speakers $344.00
Morel Elite EW538 Woofers $382.75
Focal Utopia 13KS $250.00
NVX Sound Dampening $44.67
Amp Install Kit $86.45
Misc Connectors $129.15
Labor (not finished yet) $500.00
Total $10,335.19 not including sales tax, the cost of the car, or the plane ticket, hotel to drive down and pick the car up.
Wow, that is more than half of what I paid for the car! Looking forward to enjoying it next summer.
'03 Boxster S Lapis Blue
'06 BMW 550i Jet Black
Parker986 is offline   Reply With Quote
