Old 12-16-2013, 09:47 AM   #1
PaulDash's Avatar
Radio swap not working
The Becker CR22 (CR-220 for you US types) that came with the car doesn't impress.
I wanted to swap the head unit for something that would match the factory look, but have a few more features. Mainly a Blue-tooth hands-free. The Becker Indianapolis Pro fit the bill.
After swapping the head units, the new radio lights up, shows it's receiving a radio and GPS signal, but no sound comes out. I have the M680 option and with the new head unit the DSP doesn't even light up.
Any suggestions?
PaulDash is offline   Reply With Quote
Old 12-16-2013, 07:07 PM   #2
I do not know about the Indianapolis but I do know that when the Becker Trafficpro is installed in a Boxster a pin in the plug for the back of the radio needs to be changed. The factory CDR220 triggers the amplifier through a certain pin and the Trafficpro triggers it through a different pin. I bet your new radio needs a pin switched around to trigger the amp. Search the forum for Trafficpro installation to see what I am talking about. If no info here then google it. I know I found it when installing the Trafficpro in my old Boxster 8 or 9 years ago. You will probably need a diagram of the pinouts on the Inianapolis as well.
linklaw is offline   Reply With Quote
Old 02-07-2014, 05:27 PM   #3
PaulDash's Avatar
Finally got to work on that head unit replacement.
Indeed, the #6 pin in the (yellow) plug C needs to be wired to the #5 pin in the A plug.
Now working on getting a reverse gear signal for the navigation to work.
Old 02-07-2014, 06:26 PM   #4
KevinH1990's Avatar
You can tap into it under the driver's seat on a left hand drive car.
Old 02-08-2014, 01:26 AM   #5
PaulDash's Avatar
Thanks, Kevin. That'd be a long wire.
On a 993 forum I've read that the climate control unit gets the reverse signal on a blue/gray wire. Does anybody know, if there's such a thing on the 986?
Also, would just grounding that wire fool the Indianapolis to think it's always going forward?
Old 02-08-2014, 07:54 AM   #6
KevinH1990's Avatar
Here is a post on Renntech with the instructions: Reverse Signal Wire Hook Up - 986 Series (Boxster, Boxster S) - RennTech.org Forums
Unfortunately, it looks like the photos have been deleted. They were working on a 996, but the 986 is the same.
When I installed my Traffic Pro, I did not hook up the reverse wire and the only issue is that the reverse arrow doesn't show up.
I don't know the answer to your question about the climate control.
