Old 04-16-2019, 09:19 AM   #21
flete25's Avatar
I had the same problem ..i replaced the entire cable the new cables are upgraded more thicker...that cable looks like a " y " one goes connects to the little black box in the engine compartment and the other end one goes on the starter and one on the alternator....when they go bad they heat up and wont produce any eletricity to the starter or alternator
flete25 is offline   Reply With Quote
Old 04-16-2019, 09:46 AM   #22
Will there be cake?
tonythetiger's Avatar
Originally Posted by Turbodad View Post
My problem turned out to be a weak "positive" ground in the engine compartment. It was rusty, and if I wiggled the cable and turned the key the engine would start. Disconnect the battery. It is located in a black plastic box next to the power steering reservoir. Use a screw driver to pop the box open and a 14 mm socket to remove and clean the nut.
thanks for the update! also glad it worked out for you.
