12-07-2013, 09:26 AM
#1
2000 Boxster
Hi all., I just bought a Boxter two days ago and it has 40,000 miles its a 2000 basic. I had no owners manuel and i looked here got every answer i need apart from this, The Eng light is on and the car beeps twice when it goes into second gear. The light is one due to a o2 sensor. My question is this, Is the beeping from the same problem? Also i don't have a cup holder Thanks Skoti
12-07-2013, 09:51 AM
#2
Welcome.
I'm assuming that you used a scanner to pull the codes.
I doubt that the beeping is due to the O2 sensor. For some reason, my horn beeps when I hit the brakes hard. I haven't had time to research the problem yet. When I do, I"ll post the solution. I suspect it is loose wire or connector somewhere.
2000 Boxsters didn't have cup holders - at least mine doesn't.
Also, people may tease you for leaving the "s" out of Boxster.
12-07-2013, 10:39 AM
#3
Aha & Thank you ,
12-07-2013, 10:55 AM
#4
Do you lock your doors when you are driving?
Jäger
300K Mile Club
12-07-2013, 11:05 AM
#5
Aha, Could that be it? So are the doors locked when the red light is on?
12-07-2013, 11:10 AM
#6
The red light is the indication for locked doors. Try shifting with the doors unlocked... I suspect it has something to do with the console storage door sensor switch out-of-alignment or needs replacement.
Jäger
300K Mile Club
12-07-2013, 11:25 AM
#7
Ok let me go try that and I will get right back to you, Thank you for taking the time to help with my car. I seen your posts and they helped on some other questions,
12-07-2013, 11:45 AM
#8
No that never fixed it. I noticed that its the same beep as the seat belt , Two beeps then it stops, Like if you did not have your seat belt on, I could be wrong
12-07-2013, 12:49 PM
#9
There are 2 types of cup holders- an early and a late. APPARENTLY ( as I've used neither) the late, single cup unit is the preferred version. You can buy them new at the dealer or used. There is also a good aftermarket model that's a lot easier to install- use the search mode on this forum to learn more.
12-07-2013, 01:05 PM
#10
Looks like i may be able to just find one at the local parts store.. Thanks
12-07-2013, 01:53 PM
#11
OK so it's an interior chime and not the horn beeping... Do you get a seat belt alarm on the dash when it chimes?
Jäger
300K Mile Club
12-07-2013, 03:37 PM
#12
The horn beeping when you hit the brakes is most likely the air bag bracket behind center section of the steering wheel. I had the same problem. There are lots of post on how to fix this.
12-07-2013, 04:25 PM
#13
No seat belt light nothing like that BUT i have just drove around for a few hours anytime I'm doing 25 mph it climes again like the seat belt sound , Two chime's in a row at no other speed does this happen, Even if i drop speed to 25 it chimes
12-07-2013, 04:53 PM
#14
Does your car has the on board computer (displays mpg, temp miles to empty etc.)? If so, there is a setting for a speed limit warning that you can set. If it is set, say to 25mph or so, as you accelerate through the speed you will get a warning chime.
12-07-2013, 06:02 PM
#15
Wow , Let me see , Wonder how thats fixed
12-07-2013, 06:36 PM
#16
dghii, That fixed it. I now have it set at 140MPH
12-07-2013, 08:09 PM
#17
Thanks. I just finished replacing my water pump. Now, I'm in the middle of installing heated seats and I haven't had a chance to do any research.
dghii - Good thinking about the On Board Computer. I should have thought of that.
12-08-2013, 07:04 AM
#18
Wow, Funny how many people are telling me what a mistake i have done in buying this car for my driver, My question to them is this, How many have you owned? Same answer every time, None,
12-08-2013, 07:22 AM
#19
Tell them not to complain about your steak while they are eating hamburger.
Owning a Porsche is like being married to a beautiful woman. You have to put up with a few "difficulties" from time-to-time but the benefits are outstanding.
To be honest, the cars are not that troublesome and there is a lot of help available from forums like this one. If you are willing to do a few things yourself, and search for used parts you will be fine.
Here are the instructions I'm using to install my seat heaters: Dennis Vogel: Projects - Boxster Heated Seats
Try to finding something like that for a Toyota Camry.
Good luck with your car and I'm glad you had a good first experience on this forum.
12-08-2013, 08:28 AM
#20
Thats some great points. This form has really helped me, Keep in mind this car just turned 40,000 miles and its a 2000, Let me post a pic
