Welcome.
I'm assuming that you used a scanner to pull the codes.
I doubt that the beeping is due to the O2 sensor. For some reason, my horn beeps when I hit the brakes hard. I haven't had time to research the problem yet. When I do, I"ll post the solution. I suspect it is loose wire or connector somewhere.
2000 Boxsters didn't have cup holders - at least mine doesn't.
Also, people may tease you for leaving the "s" out of Boxster.
