11-27-2013, 02:49 AM
IMS Solution installed
After much procrastination, I finally have the IMS Solution in my 2004 986 Tip. Cost almost exactly $4k (US). I do feel relieved that it is finally done, although the cost is certainly a pain. I have the old bearing assembly, and pics are attached for interest. The bearing feels smooth but has a minute amount of play, I don't know how significant. The bearing seals are intact and look good, but a very small amount of oil has leaked out over the week since it was taken out. You may be able to see the smear of oil on the bearing seal in one of the photos. I guess this is significant. There is a bit of oily but dry crud on the outer surface of the bearing carrier, but I suppose this is normal. Thanks to all who offered opinions in my recent post when trying to decide about this. Cheers and Season's Greetings to all.
11-27-2013, 05:41 AM
Engine Surgeon
Great! Which shop carried this installation out for you in Australia?
US Patent 8,992,089 &
US Patent 9,416,697
11-27-2013, 06:23 AM
Do bearings rotate the opposite direction in Australia?
11-27-2013, 07:19 AM
Yes, everything south of the equator rotates the other way.
11-27-2013, 08:39 AM
Jake, did your Excellence article on the IMS Solution come out yet?
I noticed the December issue is out but couldn't find the article.
1962 VW Beetle
1966 Triumph Spitfire
2003 Porsche Boxster S
2005 Ford F-150 Monster Truck
11-27-2013, 03:38 PM
Only when you hit reverse gear....You guys are such clowns, didn't they teach you anything in school
2001 MV Agusta F4.
11-27-2013, 08:02 PM
Must be a relief to finally have this done.
Bust open that seal and let's see what the bearings themselves look like!
:ah:
11-28-2013, 03:23 AM
Jake, the work was done by Weltmeister Porsche here in Melbourne, the largest independent Porsche service centre in this country (so they say). My car goes to them for routine service, and the previous owner took it to them as well. They tell me that they have done quite a few IMS Solution installations now, and in cars with the single-row bearing, they will install the Solution kit only.
And yes RawleyD, feeling rather relieved and happier to drive it. It even runs more smoothly (OK, I am dreaming?). Have not had time to open the bearing seals, but will do soon.
And to others with theories about the effects of gravity on this end of the planet, I recommend you come here for a holiday and find out for yourself. We have some great driving, among other attractions!
11-28-2013, 01:41 PM
Im not a bearing expert but those pics look like its fine....
11-28-2013, 04:34 PM
Engine Surgeon
I hear that all the time from those we have installed the technology for here.
The one time that I brought this point up on another forum I was chastised by the vendor haters. They said that it was absolutely impossible for this retrofit to allow the engine to run smoother than it previously did.
People.....
US Patent 9,416,697
11-29-2013, 12:52 AM
Took the outer seal off just now, Everything looks OK, and the bearing spins more freely with the seal off. But there is no lubricant other than a film of light oil that I can see, so I suppose the original lubricant is gone. It seems that the bearing was not in imminent danger of failing, but I wonder what the long term would have brought. I had an engine blow up in a car years ago, and finding a good used replacement engine seemed fraught with risks, so I would not enjoy doing it again, for the Boxster. I expected that the bearing would be OK. I'm still happy I did this.
11-29-2013, 10:09 AM
Autobahn Glanz
You did the right thing, you'll sleep better with that single row piece of crapp out of there, and yes mine ran smoother with the new solution in, or it could have just been my relief that I installed it perfectly and my pride made me more happy
11-29-2013, 04:12 PM
Beginner
+1, and as for the running more smoothly, why not? The IMSB has clearance (rattle) which by definition plays into the valve timing in some manner. If the solution reduces a minute variation in valve timing by tightening up the correlation between the crankshaft and valve timing it stands to reason the engine would run more smoothly. My story and I'm sticking with it.
11-29-2013, 04:42 PM
Engine Surgeon
Absolutely.. But the "vendor haters" always have to ******************** about something.
US Patent 9,416,697
02-09-2014, 07:02 PM
I'm considering a Boxster or 911 sometime in the next year. I'm looking at the Solution and Retrofit as preventative maintenance. I've been reading what Jake Raby and LN have been doing. Looks like a very thorough and well engineered set of solutions. I even spoke with the local independent shop that is authorized to install the Solution/Retrofit.
So, as someone considering buying in to the Porsche family I have some IMS economic observations or maybe questions.
From looking through various forums the installed cost for the IMS Retrofit is about $2,000 and the Solution is about $4,000, do I have that more or less right? Other work would probably be completed at the same time, but let's set that aside for a bit.
The recommended Retrofit life time is 50,000 miles, and the life of the solution is engine life time, right?
So, at double the cost the Solution pays for itself after 100,000 miles? I've seen reports of +200,000 mile and up Boxsters and 911's. So if you keep a Porsche for longer than 100,00 miles from date of Solution install it may be worth the extra cost.
Assume that you still have to replace the clutch every 50,000 miles and the effort to get to the clutch is the same as the IMS. Therefore in reality it takes a very, very long time for the Solution to pay for itself. Am I right or wrong?
02-09-2014, 07:30 PM
I am my own mechanic....
Does it come with a special tool to measure the piece of mind?
Can the relief be put into words? Can you describe it?
'08 VW Touareg T-3 wife's car
02-09-2014, 09:04 PM
Engine Surgeon
The people who install the IMS Solution are generally not considering ever selling the car. To the, it pays for it's self right away.
You can't look at the different offerings from a price point of view, if you are doing that you generally won't keep the car forever and therefore should probably just use the cheaper product and let the car go after a while.
Cost is never a consideration for those who call us looking for the IMS Solution to be installed here. I think I have only had two people ever ask me about the differences in cost. Since the IMS Solution was released we haven't applied a single row classic retrofit, and only one person has asked for one. I set him up with the Single Row Pro, because its a mid price point offering.
Most people are going to the Solution, because its a complete design change that omits the ball bearing completely. People that understand how this works always say "it just makes sense".
US Patent 9,416,697
02-10-2014, 01:24 PM
It's about 3 months now since I had the Solution installed. I am happier with the car and drive it more often now, so clearly I have gained a benefit of sorts that justifies the cost, to me. And I have more or less forgotten about the financial cost. The impression that the engine is quieter and smoother, especially when idling, is still with me. The idle sound reminds me of a 993 that I test drove years ago, and I loved the sound of that engine. And I will probably keep the Boxster longer. So I am a happy customer.
02-10-2014, 02:43 PM
I don't know many people that don't ask what the price of something is before they buy it, maybe I'm out of my league here.
Really, single row IMS buyers are buying only the Solution and dual row IMS buyers are some mix between Retrofit and Solution? I guess the data says that dual row bearings weren’t that bad (weren’t as bad as single row) in the first place.
I was OK looking at used Porsches for my next car with the expectation of spending about $4k to $5k on preventative maintenance, IMS, brakes, water pump, and so on. But, if the IMS is fix $4k alone I’m probably out of the used Porsche market. I’m not a teen ager, I have pretty good income, I can buy a pretty good toy, there has to be a better option. Heck, I’ve been driving minivans and SUVs for 25 years, a Nissan Sentra is going to feel like a sports car.
I do understand the peace of mind value. One day you’ve got a fantastic powerful sports car the next day you’re in the pinewood derby. Engine rebuild/replace costs run from what $8K to $20K installed (not sure if $8k is too low)? So, an IMS Solution is 20% to 50% the cost of a rebuild?
To me the Solution makes the most sense on an engine rebuild. How long should a well maintained engine last? I know there's an example on YouTube of a million mile Porsche but that owner went through three engines. So let’s say a well maintained Porsche engine will last 350,000 miles or six clutch-IMS Retrofit changes. If you said the IMS Retrofit bearing increases the clutch replacement cost by $600 then after six clutch-IMS Retrofit changes the total IMS cost is $3,600, the Solution doesn’t not pay for itself by the 350,000 mile engine failure.
I’m sorry, I probably sound whiney. I think the Solution and Retrofit IMS fixes are clever. I can’t imagine how much collectively Porsche owners have lost on resale value from the D-chunk and IMS design short comings. It’s not hard to imagine that these issues cost Porsche in reputation and new sales. Porsche owners are losing resale value, lower resale value means that prospective buyers have less cash to put toward their next purchase.
Anyone want to try to talk me back in to the used Porsche market?
02-10-2014, 03:47 PM
The Solution makes the most sense for someone that plans on keeping the car long term, like Jake mentioned. If you are going to keep the car for an intermediate time and you need a clutch, get the retrofit. For someone who changes cars on a regular basis, get one, drive it like you stole it, have fun, and move on to the next desire. Regardless, the Boxster is an incredible value with or without the additional cost of the IMS Solution or retrofit.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
