Old 11-20-2013, 11:26 PM   #1
Tucker2's Avatar
Key button
Purchased an '02 BS couple months ago. Key I have has a small button on the side of it that I can't find any documentation on. Any clue on what it does?
Current: 981 Cayman
Former: '02 BS and '08 C
Tucker2 is offline   Reply With Quote
Old 11-21-2013, 04:26 AM   #2
gregdacat's Avatar
My 2002 base has a tiny button activated flashlight on the valet key. Could this be what your are referring to?
Greg
2002 Triple Black, Desnorkled, Bumper Plugs, LN IMSB Upgrade
gregdacat is offline   Reply With Quote
Old 11-21-2013, 05:17 AM   #3
Are you talking about the central lock/unlock button near the radio?
mump is offline   Reply With Quote
Old 11-21-2013, 06:45 AM   #4
You're talking about the little square button on the side of the key? You would press that to actually open up the key and access the battery.
Tieniber is offline   Reply With Quote
Old 11-21-2013, 06:59 AM   #5
recycledsixtie
recycledsixtie's Avatar
I have a 2001 Boxster base with no remote key but strictly a manual key with a button which if pressed should light up a small bulb in the key which helps you find the keyhole. I pried it apart after taking the key off the key ring. Inside mechanism is really delicate which operates the light. Got a new battery and replaced the old one.
Worked a few times then the internals broke. If I remember right I pried open the cover of the key with a penknife.
Old 11-21-2013, 06:30 PM   #6
Multi-Boxer Driver
Deserion's Avatar
The tiny little "button" on the side of the remote key is the pin (on a spring) that holds the keyblade into the remote. If you take the button cap off, it'll be easier to see.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
