I have a 2001 Boxster base with no remote key but strictly a manual key with a button which if pressed should light up a small bulb in the key which helps you find the keyhole. I pried it apart after taking the key off the key ring. Inside mechanism is really delicate which operates the light. Got a new battery and replaced the old one.
Worked a few times then the internals broke. If I remember right I pried open the cover of the key with a penknife.
