Old 11-13-2013, 07:14 AM   #1
jb92563's Avatar
01 S, Manual 6 - Randomly will not start
I have lately been experiencing a condition where when I turn the key to start the car nothing happens.
There are no warnings or any other apparent signs of trouble, the starter simply makes no motion.
After a few attempts though the car does start as normal.
This morning it happened again and since my leg muscles were sore from playing Baseball the evening before, I made a focused effort to make sure I was depressing the clutch all the way in, and it fired right up.
Is it possible that I have an intermittent or failing clutch switch?
Where might it be located?
Do they generally fail or just get loose and need to be adjusted and re secured?
What else could it be if not that?
Coincidentally it first started after my Autocross racing last weekend.
Old 11-13-2013, 07:15 AM   #2
Could be the switch in your ignition barrel, too.
Old 11-13-2013, 07:28 AM   #3
jb92563's Avatar
Good point.
All the dash lights etc do act normal but I suppose the START position could be the culprit as well.
I'll jiggle the key next time it happens and that should reveal whether its the ignition switch.
Old 11-13-2013, 07:31 AM   #4
Having said that, mine does this sometimes - if I kill the ignition and then quickly restart, sometimes it won't respond - and I put a new switch in fairly recently that I am pretty sure is just fine...
Old 11-13-2013, 08:34 AM   #5
Try jumping the clutch switch wires. If its starts, the problem is the switch.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 11-13-2013, 01:15 PM   #6
doragman's Avatar
This happens occasionally to me also ...pump the clutch pedal a few times and it always starts ...need to replace the clutch switch eventually
'99 986 Baton Rouge, LA
doragman is offline   Reply With Quote
