10-25-2013, 10:55 AM
Why would these MAF wires be spliced?
Cleaned the MAF yesterday, noticed the PO had the red and blue wires spliced. Doesn't look like they are spliced into anything anymore, but what WOULD they have been spliced into? I can't think of anything you would want to splice into the MAF wires.
10-25-2013, 11:13 AM
They don't look like splices, they look like clamp on wire taps where someone had something attached.
10-25-2013, 11:19 AM
Voltage testing??
Jäger
300K Mile Club
10-25-2013, 11:26 AM
More likely one of those A/F "tuner boxes" used to lie to the DME about what is really going on in an attempt to eek a couple of HP out of the car.
10-25-2013, 12:06 PM
Right, they are taps...splices...same thing.
I suppose it could have been something like the resistor trick...eek
10-25-2013, 12:44 PM
I'd expect someone to try something like that on an old Beamer but not Porsche... Weird
If you are interested in a Comfort-Top module, please visit:
https://www.enhancedautomods.com/shop/comfort-top
10-25-2013, 01:15 PM
Yep that's what some tuner needs to get a spot on job done on a cheap porsche  Got it on my 986.... 50K POT and 50kohm resistor is all you need. Safely hiden in the cabin/console compartment.
Magic weapon lol
10-25-2013, 01:17 PM
haha....you mean like when I chipped my bmw? Thats totes different...a chip versus a chinsey resistor
10-25-2013, 02:00 PM
Magic weapon lol
Hahaha, not sure if you're joking.... ?:/
10-25-2013, 02:13 PM
fooling downstream vortex vibrations?? hacking your O2?? spring rates on the larger TB?? Nah?! Now that's what freedom means +525 horses minimum! Oh and Chinese Made Tires!
I was sure that you guys had it all sorted already.
10-25-2013, 02:32 PM
Haa!!! Beat you on the tires. Homemade... 100 grit sandpaper... Don't even need snow chain anymore.
10-25-2013, 02:33 PM
Had found something similar to that on my 2001 Boxster, where the wire had been tapped like with a voltage tester. It was so bad I had to replace the entire wiring for the MAF connector, and the only way to do that was to purchase the entire wiring loom.
10-25-2013, 02:38 PM
Oh hang on, not too fast...
My tires are so goddamn cheap they "melt" after a good heat cycle. 100 times more sticky than Performance tires, and 100 grit  That's how it done
10-26-2013, 09:01 AM
Like! Like! Like! Like! Like! Like! Like! Like! Like! Like! Like! Like!
10-26-2013, 09:11 AM
I think you guys should post in the cheap tires thread haha
Sent from my iPhone using Tapatalk - now Free
10-26-2013, 11:07 AM
And to think I was just about to put one of my spare log taper 50k pots in.
10-26-2013, 09:22 PM
I'm not the one of fills my tires with nitrogen....
