Old 10-14-2013, 09:46 PM   #1
Chirping sound
need suggestions on noise coming from engine (chirping) when engine is rev. up and moving,the faster the car goes the faster the noise gets
, just replaced water pump last june,2013 , 99 boxster have 115,00mi. now.
pedot99boxster is offline   Reply With Quote
Old 10-14-2013, 09:58 PM   #2
The Radium King's Avatar
bird nest in the engine bay?
Old 10-14-2013, 10:15 PM   #3
epapp's Avatar
Is it related to engine RPM or vehicle speed? You allude to both
epapp is offline   Reply With Quote
Old 10-14-2013, 10:23 PM   #4
both, when I pull into my garage and park it the noise is there when i rev it up a little but not on idle, and it is noticeable when I start moving the vehicle starts up slow chirping then gradually picks up when the car gains speed. I'll try to post a video tomorrow on you tube
Old 10-14-2013, 11:01 PM   #5
drive belt too tight?
BTfd2e93 is offline   Reply With Quote
Old 10-15-2013, 02:02 AM   #6
Steve Tinker's Avatar
Try removing the serpentine belt and run the engine (for a minute or so no longer) to see if the noise disappears - if it does it is either the alternator clutch, tensioner/idle rollers. power steering pump or A/Compressor.
2001 MV Agusta F4.
Old 10-15-2013, 05:45 AM   #7
thom4782's Avatar
+1 on Steve's advice. In my case, it was a failing water pump. The chirp lasted a day before the WP pulley fell off.
Old 10-17-2013, 12:03 AM   #8
I think I found the culprit, power steering pulley/ pump making noise, I posted a video on you tube here's the title of the video "Boxster 986 bad power steering pump" from pedot pedotski I check the steering fluid and its dry on the stick, will add some Pentosin tomorrow and see what happens, maybe the fluid got really low and messed up my steering pump. is it hard to change the power steering pump or this is just the pulley that needs replacement?
Old 10-17-2013, 01:38 AM   #9
If the fluid level has dropped significantly, the problem will be in the pump - the pulley is only an extension to the pump shaft.
Your next problem after topping up the PS resevoir is find in the fluid leak - it could be external (you will see the leak) or it could be in the steering rack (you won't see the leak).
If the pump has run dry, it will probably require replacement.....
2001 MV Agusta F4.
