Old 09-27-2013, 07:44 PM   #1
FLAT64EVER's Avatar
Coolant Cap saga ...
Ok I replaced my coolant cap with the latest - 996106 447 04. My indie had both the blue -which I tried first - and a black that I just put on.
He showed me both packages, and they both had the 996106 447 04 stock number.
Both still allow condensation on the rear lid above the cap!!?? The black is maybe a little better.
Anyone else having difficultly with condensation with the new caps?
Cheers.
2001 Boxster S SOLD
Seal Grey/ Graphite Grey -Design Package-Sport Design Package- PSM- Litronic Lights-Headlight Washers
XRL (GT3) 18" Wheels-Heated Seats-CD Center Console
FLAT64EVER is offline   Reply With Quote
Old 09-27-2013, 08:39 PM   #2
Hmm. Maybe try checking the coolant bleeder valve - might be not fully closing/sealing.
Old 09-27-2013, 10:26 PM   #3
+1 for your bleeder valve, specifically, one or both of the O-rings. I had the same issue on 2 Boxsters. Replacing the O rings solved condensation issue on each of the cars.
dghii is online now   Reply With Quote
Old 09-28-2013, 12:36 AM   #4
Nimbus117's Avatar
Mine was the same after replacing the coolant cap - no difference. I tried tightening the screws on the bleeder valve cover which made it worse, next thing is replacing the O rings as mentioned above.
2003 Boxster 2.7L
2010 Civic Type R
Old 09-28-2013, 04:39 AM   #5
kk2002s's Avatar
I just did the upgrade. I don't get the large amount of slippery (coolant ) condensation any more. I do get some very mild wetting. It's not all the time. I'm thinking, especially as it's getting cooler, that this is warm (Expansion tank, cap) on cold metal (Trunk lid). It doesn't feel slippery like before. The warmer the day, sometimes no condensation. I am going to look at the bleeder as I have never looked at it before to see what is going on there
Seal Grey
Old 09-30-2013, 02:38 PM   #6
I had condensation on the trunk lid until I changed my heater core last Friday. Old core had brown foam material attached that lines the vents. Leaking coolant looked like grease at the base of the heater core compartment. Also, had coolant smell through the vents. All good now.
1080Z is offline   Reply With Quote
