Old 09-23-2013, 07:29 AM   #1
Roll bar question
Can anyone tell me how to separate the padding from the metal roll bar? I need to get them apart but don't want to force it until I know what I'm doing. There are no obvious fixings.
Dek32 is offline   Reply With Quote
Old 09-23-2013, 07:54 AM   #2
http://986forum.com/forums/general-discussions/9879-how-take-off-rollbar-padding.html
Wret is offline   Reply With Quote
Old 09-23-2013, 08:02 AM   #3
and, as is so often the case, SIYF
'99 black 986
Old 09-23-2013, 09:16 AM   #4
jsceash's Avatar
I do this often since I purchased a Brey Krause extension. There are 3 pins on each hoop cover. One about 2" from the end and one on the top in the middle. Move the seat ahead as far as possible and fold front if so equipped. Get a firm grip just up from the bottom about 2-3 " on one end and pull. Repeat on the other end then in the top center. I never used any pry tool and still do not. If the grommet come off with the hoop cover they can be easily twisted off as the pins is threaded. The bushing gradually gets too loose, I replace the plastic grommets every other time.
