Old 09-14-2013, 10:08 PM   #1
jb92563's Avatar
High beams not working
When I push the stalk forward to the highbeams setting they do not come on, yet when I pull rear to blip the highbeams they work.
Is there a relay somewhere that might be stuck/dead?
Stick issue?
Ideas/suggestions?
Old 09-15-2013, 05:55 AM   #2
noneoftheabove
From what I remember if one high beam goes it causes the other one not to work. Check both bulbs tell us how it goes! Someone I know had a similar problem because of a bad ground.
RoadsideStig is offline   Reply With Quote
Old 09-15-2013, 07:05 AM   #3
BruceH's Avatar
Good chance it is the headlight switch. Easy to replace, but not cheap.
Pelican Parts - Product Information: 996-613-535-00-M100
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 09-16-2013, 03:51 AM   #4
Do you have daytime running lights? If so, if the headlight switch is off and the car is running your headlights will be on and you can still flash your high beams; however, you cannot turn the high beams on without also turning on the headlight switch.
Brad
southernstar is offline   Reply With Quote
Old 09-16-2013, 11:32 AM   #5
jb92563's Avatar
No daytime running lights.
I'll check to make sure both Highbeam bulbs are working tonight.
Wow, thats a pricey switch, hope thats not my problem.
Old 09-16-2013, 12:06 PM   #6
BruceH's Avatar
Unfortunately it is not uncommon for that switch to go bad.
DEPO Tail Lights
