Old 09-10-2013, 09:09 PM   #1
Cool Metra 70-1784 Receiver Wire Harness
Hi,has anybody installed a 1 din head unit in their Boxster using the Metra 70-1784 Receiver Wire Harness. I have a 2004 non - Bose system and on the Crutchfield site it says this is the part,But every other place says NO even the Metra website.
the1andonly is offline   Reply With Quote
Old 09-11-2013, 04:06 AM   #2
KevinH1990's Avatar
I think your car has the MOST fiber optic interface. The pictures of the Metra 70-1784 I see appear to be of a traditional wired interface, so I don't think it will work. Search on MOST and you will probably find that most people have a challenge upgrading the sound system on the 2003 and later cars.
Good luck
KevinH1990 is offline   Reply With Quote
Old 09-11-2013, 06:39 AM   #3
Steve03986's Avatar
To install an aftermarket HU in an 03 or 04, you need to bypass the MOST. I installed a single DIN radio and a new amp, which went in the frunk. I ran the amp wiring through the firewall opening under the steering wheel.
The factory amp has two connectors - one is the MOST from the factory radio and the other is for the speakers. If you disconnect the large plastic speaker connector from the factory amp, you can connect the speaker leads from the new amp to the existing speaker wiring.
Alternately, if the new HU has a built-in amp, you may be able to run the speaker wires through the firewall opening and connect to the existing speaker leads.
In either case, however, you have to disconnect the factory amp.
Hope this helps.
Steve03986
2003 Boxster S
Seal Grey, Grey leather, Tip
Steve03986 is offline   Reply With Quote
