Old 09-06-2013, 12:08 PM   #1
Beelzy's Avatar
Sometimes my 04 base won't shift out of Park....
Can someone please explain why it only happens sporadically? Like when I am more than fashionably late, or trying to be cool leaving the grocery store parking lot....with ice cream.
Thanks for humoring me, and providing a solution.....perhaps.
Beelzy is offline   Reply With Quote
Old 09-06-2013, 12:43 PM   #2
When it happens do your brake lights work ?
Ian c is offline   Reply With Quote
Old 09-06-2013, 01:01 PM   #3
BYprodriver's Avatar
Yeah, brake light switch can get loose on you. If not that maybe a little solenoid that prevents shifter from coming out of park unless foot brake is applied. Had a Land Rover Discovery pull that on me in the middle desert. Maybe that's why they named it Discovery?
By the way usually you can pull off the shifter trim plate & manually unlock the solenoid if that's the problem.
Old 09-06-2013, 04:17 PM   #4
Beelzy's Avatar
Thanks for responding Gentlemen.....off to the garage I go.
Cheers!
Old 09-07-2013, 02:54 PM   #5
My 996 tip did that occasionally. It turned out to be the plastic ignition piece on the back of the switch. Didn't figure it out until a lot of other stuff started happening, but once I replaced it I never had the problem again. It was another 2 or 3 years before I sold the car.
2001 Boxster S 3.6, 2003 E46 M3, 94 968 Cab, 80 911 Weissach Edition, BMW 1200 CLS
smshirk is offline   Reply With Quote
Old 09-07-2013, 03:51 PM   #6
Ours did too , but showed plenty of other signs that the ign switch was the culprit
All kinds of cels and radio not working etc ...
Old 09-08-2013, 09:39 AM   #7
Beelzy's Avatar
So, can I just leave the shifter in neutral and use the parking brake if I am paranoid until I fix it?
Hmm.
Old 09-08-2013, 09:41 AM   #8
Beelzy's Avatar
It happens only periodically, so I must wait until the problem presents itself again.
Old 09-08-2013, 09:54 AM   #9
You still need to have your foot on the brake to shift into drive or reverse ...
Old 09-08-2013, 09:56 AM   #10
Do you have any other issues ?
Hard to get the key out , radio not working , air conditioning fault codes etc
Old 09-08-2013, 10:07 AM   #11
Beelzy's Avatar
No other symptoms......as of yet.
Old 09-08-2013, 10:18 AM   #12
You could start cleaning contacts and switches rather than wait for it to happen again ?
Old 09-09-2013, 06:39 AM   #13
I have the same problem with my 1999 Boxster.
I've replaced the brake light switch, but I still have the problem.
I beleive it its the ignition switch. My switch was replaced about three years ago.
My solution:
I just press the brake pedal and the shifter button as I turn the ignition switch and I am good to go.
It is the best anti-theft device ever:-)
MNC-I
mnc-i is offline   Reply With Quote
Old 09-09-2013, 07:00 AM   #14
Beelzy's Avatar
Pardon the Freudian slip, but I like how you think outside the Box.......lol!
Old 09-09-2013, 07:44 AM   #15
I don't think you can start the car if its in Neutral. I think the car has to be in park
01 Boxster - Lapis Blue - Aerokit II Daily Driver.
98 Pontiac sunfire - Winter beater- TRADED IT IN FOR 200 DOLLARS
2010 Honda Civic Coupe - Gunmetal Grey - Lease ended and returned
2011 Mercedes Benz GLK350 - Gunmetal Grey
ramo80 is offline   Reply With Quote
