-   -   Sometimes my 04 base won't shift out of Park.... (http://986forum.com/forums/boxster-general-discussions/48245-sometimes-my-04-base-wont-shift-out-park.html)
Beelzy 09-06-2013 01:08 PM
Can someone please explain why it only happens sporadically? Like when I am more than fashionably late, or trying to be cool leaving the grocery store parking lot....with ice cream.
Thanks for humoring me, and providing a solution.....perhaps.
Ian c 09-06-2013 01:43 PM
When it happens do your brake lights work ?
BYprodriver 09-06-2013 02:01 PM
Yeah, brake light switch can get loose on you. If not that maybe a little solenoid that prevents shifter from coming out of park unless foot brake is applied. Had a Land Rover Discovery pull that on me in the middle desert. Maybe that's why they named it Discovery?
By the way usually you can pull off the shifter trim plate & manually unlock the solenoid if that's the problem.
Beelzy 09-06-2013 05:17 PM
Thanks for responding Gentlemen.....off to the garage I go.
Cheers!
smshirk 09-07-2013 03:54 PM
My 996 tip did that occasionally. It turned out to be the plastic ignition piece on the back of the switch. Didn't figure it out until a lot of other stuff started happening, but once I replaced it I never had the problem again. It was another 2 or 3 years before I sold the car.
Ian c 09-07-2013 04:51 PM
Ours did too , but showed plenty of other signs that the ign switch was the culprit :D
All kinds of cels and radio not working etc ...
Beelzy 09-08-2013 10:39 AM
So, can I just leave the shifter in neutral and use the parking brake if I am paranoid until I fix it?
Hmm.
Beelzy 09-08-2013 10:41 AM
It happens only periodically, so I must wait until the problem presents itself again.
Ian c 09-08-2013 10:54 AM
You still need to have your foot on the brake to shift into drive or reverse ...
Ian c 09-08-2013 10:56 AM
Do you have any other issues ?
Hard to get the key out , radio not working , air conditioning fault codes etc
Beelzy 09-08-2013 11:07 AM
No other symptoms......as of yet.
Ian c 09-08-2013 11:18 AM
You could start cleaning contacts and switches rather than wait for it to happen again ?
mnc-i 09-09-2013 07:39 AM
I have the same problem with my 1999 Boxster.
I've replaced the brake light switch, but I still have the problem.
I beleive it its the ignition switch. My switch was replaced about three years ago.
My solution:
I just press the brake pedal and the shifter button as I turn the ignition switch and I am good to go.
It is the best anti-theft device ever:-)
MNC-I
Beelzy 09-09-2013 08:00 AM
Pardon the Freudian slip, but I like how you think outside the Box.......lol!
ramo80 09-09-2013 08:44 AM
I don't think you can start the car if its in Neutral. I think the car has to be in park
