Old 09-05-2013, 03:13 PM   #1
evo-r's Avatar
Question Wheel alignment off after wheel bearing replacement??
This doesn't make sense but I just noticed my wheel alignment is off (drift to the right)... again?
After I purchased the car this past March I had replaced all 4 tires and did a 4 wheels alignment (on the stock 17"). I've only put less than 2k miles since and I don't think I had hit any major pothole or curb. I did put on a set of 19" and ran for about 1k miles then switch back to the 17" 500 miles ago. My rear passenger wheel bearing was replaced 2 weeks ago and I don't "think" the alignment was off before that but this doesn't make sense? I know I need to replace the rear trailing arms due to bad bushings. Before I spend another $120 bucks on the Hunter HawkEye alignment i would like to know the root cause. Any idea why my alignment went out so quick?
His: 2003 Boxster & 2008 MDX
Hers: 2011 Golf TDI
evo-r is offline   Reply With Quote
Old 09-05-2013, 03:45 PM   #2
BYprodriver's Avatar
A drift to the right is usually caused by the normal "crown" of most roads that aids water drainage to the right. After setting all tires to the same PSI used during the alignment, drive on a flat road with no crown like the middle lane of a 3+ lane freeway.
If it still drifts, the wheel bearing replacement procedure may have altered a alignment setting.
Old 09-05-2013, 03:52 PM   #3
Unfortunatley, it doesn't take much when working on the on the suspension or wheel hubs to alter the alignment. I'd consider that to be your most likely root cause.
This is also known as the "What Ever Was Repaired Last is the Place to Start for The Problem You Have Now" theorem.
Old 09-05-2013, 04:57 PM   #4
evo-r's Avatar
Thanks and the first thing I checked was my tire pressures and they are the same as the alignment report. I drove the car in left, center and right lanes of highway and all needed similar steering wheel correction to the left. Sounds like the wheel bearing job caused it.
Looks like the wheel bearing job was the cause, thanks! So should I wait until the 2 trailing arms are replaced then redo the alignment?
Hers: 2011 Golf TDI
Old 09-05-2013, 05:41 PM   #5
I am my own mechanic....
Timco's Avatar
Since we can't exactly rotate, I'd keep it aligned after these procedures and if it drifts when flat.
'08 VW Touareg T-3 wife's car
Old 09-05-2013, 08:13 PM   #6
No hard rule here. Depends on how bad it is and how long/miles until you replace the 2 trailing arms. You get the idea.
Old 09-09-2013, 07:05 PM   #7
evo-r's Avatar
Called up the indy that did my rear wheel bearing and asked if the bearing replacement had affected the wheel alignment and the guy said "no", and that whatever they did to replace the wheel bearing shouldn't affect the wheel alignment.
Hers: 2011 Golf TDI
Old 09-09-2013, 08:21 PM   #8
Timco's Avatar
Only needs alignment if the tie rod end pin connection is removed. Forget what the rear is called. Maybe if the bearing had slop, but otherwise a bearing would not cause a need for alignment.
I did all 4 of mine.
