Old 08-28-2013, 09:57 AM   #1
Perfectlap's Avatar
Those of you with Low Temp Thermostats
Have you like me, noticed that temp always seems to stay ver near the 180 hash mark? Even after a long drive. With the old t-stat it was always in the middle or edging towards the next hash mark.
Granted some our mechanics on the forum have pointed how inaccurate the dash gauges are in general. But this does get me thinking whether running an old coolant cap, that presumably is not keeping pressure as well as the new cap, can somehow prevent the coolant from doing its job, resulting in a hotter running engine.
Or perhaps the combination of an updated cap and low temp t-stat provides a significantly better performing coolant system?
Old 08-28-2013, 10:09 AM   #2
As you are running a MY 2000 Boxster you can always use the AC hack to show the engine temp in Celcius, by that you will be in control of what is going on in the cooling system. Mine never exceeds 90 C if I have the AC fans running and stays around 83 on the highway. I do not trust the info given by the temp needle
spongebob is offline   Reply With Quote
Old 08-28-2013, 10:58 AM   #3
AKnowles's Avatar
Either you are in a very cold area or you are not pushing it enough. In 60~70 temperatures I have noticed that behavior. So long as I kept the engine under 4000 RPM. Above that, it'll move up. My morning ride 80 degrees) and it was just back of the 8. In the afternoon temps (100+) I'm in the middle to the back of the 0.
Old 08-28-2013, 12:57 PM   #4
If I understand thermostats correctly, the temperature rating of a thermostat refers to the temp at which it opens only and should have no bearing on the operating temp of a fully warmed up car as any thermostat should be fully open at that point.
'99 black 986
Old 08-28-2013, 01:09 PM   #5
How right you are Mark.
Brad
southernstar is offline   Reply With Quote
Old 08-28-2013, 01:29 PM   #6
Perfectlap's Avatar
So why is there a very small increase in output with a low temp t-stat? I believe this claim is made on LNE's website. I may be nuts but I definitely feel a difference, albeit marginal.
Old 08-28-2013, 01:39 PM   #7
Perfectlap's Avatar
The ambient temp has been about 80 lately. But in the past the same below 4K RPM driving definitely resulted in the needle tilting closer to the next hash mark. If this was a one off I wouldn't have thought much of it. But post t-stat I don't ever recall the temps tilting left this consistently. And like I said in the other post its peppier.
Old 08-28-2013, 02:19 PM   #8
AKnowles's Avatar
Hmm, atmospherics? I mean cooler moister air possibly? If so, that would assist the cooling system efficiency plus provide some improved engine performance.
Old 08-28-2013, 02:39 PM   #9
Perfectlap's Avatar
hmm...it's definitely been raining more for an August.
Old 08-28-2013, 02:47 PM   #10
Not withstanding the many theoretical debates on whether a 160 will result in lower "steady state" (after full warm up) temperatures than the stock, I believe it has been reliably reported that IN FACT (e.g. based on testing) the 160 DOES result in lower operating temperatures, both coolant and oil.
runjmc2 is offline   Reply With Quote
Old 08-28-2013, 02:53 PM   #11
thom4782's Avatar
In my case, I find that with the AC on my temperature needle now points consistently left of the 180 hash mark whereas before it pointed to the middle of the 8. This must mean that airflow over the radiators helped by the low speed fans keeps the coolant at a lower temperature than before. This makes sense because A low temperature thermostat allow the coolant circulation to start at a lower temperature.
Old 08-28-2013, 06:48 PM   #12
Porsche "Purist"
Paul's Avatar
The thermostat controls the amount of cooled coolant entering the motor:
1987 924S. 2002 996TT. PST-2
Old 08-29-2013, 02:12 AM   #13
madmods is offline   Reply With Quote
Old 08-29-2013, 02:14 AM   #14
Old 08-29-2013, 02:35 AM   #15
Steve Tinker's Avatar
madmods, I'm sorry to tell you that you are so full of crap that its coming out of your ears - you obviously know more than the combined experience of all those who contribute to this Forum.....
Please use the search function and read up on this subject and make a valuable contribution - you are quickly dropping into the troll syndrome....
2001 MV Agusta F4.
Old 08-29-2013, 02:37 AM   #16
Old 08-29-2013, 02:48 AM   #17
How do you do the "AC Hack"?
Van
Old 08-29-2013, 04:45 AM   #18
I am prepared to accept the experience of perfectlap and others who have the LN thermostat. I suppose if the thermostat opens at a lower temperature and the cooling system is able to maintain that temperature in operating conditions, then it will be lower. At a certain point in stop and go traffic, however, the temperature is apt to rise regardless - however, the car with the lower initial coolant temperature should still remain lower until both cars reach the maximum capability of the system.
Brad
Old 08-29-2013, 06:07 AM   #19
Homeboy981
Homeboy981's Avatar
I have found these same results too. The 160 degree thermostat DOES seem to lower the coolant temps. While the temps may rise in traffic, with spirited driving and while running the A/C on a hot day….it never seems to get AS HOT as before the Low Temp Thermostat was installed….Lower temps DO = more HP - now IF only the REST of the care was built as well as the thermostat!
Old 08-29-2013, 07:40 AM   #20
Perfectlap's Avatar
question: does much more frequent expansion and contraction not have some unintended consequences to the engine itself?
