Old 08-18-2013, 06:36 PM   #1
Perfectlap's Avatar
gargle when I lift?
Name this sound if you can. First its a gargle and not the typical rumble of an aftermarket exhaust. The gargle occurs when I'm cruising along in first gear usually. I step on the gas from a stop, for instance when exiting the parking garage where everything echoes, when I approach a stop sign and get off the gas, after a short pause I hear the gargle. Seems to be tied to the throttle action if you will. Coil packs?
Old 08-18-2013, 06:49 PM   #2
98670914's Avatar
I vote for exhaust baffle or heat shield.............
Kevin
01 Boxster S
02 S Hulkster
98670914 is offline   Reply With Quote
Old 08-19-2013, 05:22 AM   #3
Is this a new noise? How loud? My 987 has always had a similar noise when off-throttle/engine braking.
Old 08-19-2013, 05:56 AM   #4
edc
550 Anniversary
edc's Avatar
I've had this gargling/farting noise on over run at low revs since the new silencer and mnaifolds has been on.
Old 08-19-2013, 06:42 AM   #5
Drive the new Boxsters! They have a great gurgle, especially with the PSE, when you let the throttle breath.
Old 08-19-2013, 08:15 AM   #6
Perfectlap's Avatar
Not new. My indy hooked it up to the autologic and it didn't come back with anything.
It's definitely post-stock exhaust.
I have a very cool gurgle but that you hear at speed. The gargle is a parking lot/residential street cruising speed thing.
p.s.
I sat in the 981S and a 964 RS recently. The new Boxster seems HUGE compared to the old Carreras.
Old 08-19-2013, 08:26 AM   #7
duuuuuuu.
Old 08-19-2013, 04:46 PM   #8
I sat in the 981S
Careful! That is a very slippery (and expensive) slope my friend.
fatmike is offline   Reply With Quote
