Old 01-14-2006, 01:59 PM   #1
changing tiptronic shift plate and shifter - diy?
Hi everyone,
I bought a new silver tiptronic shift plate and a black leather, silver knobbed tiptronic shifter to replace my old set with was all black and looked a bit too plastic for my liking. My question is, is this a DIY project? If so, how? :dance:
Thanks for any and all help.
Jimmy
jimmylau is offline   Reply With Quote
Old 01-14-2006, 02:25 PM   #2
Hi,
This is definitely a DIY Project. Proceed as follows:
● Turn Ignition ON
● Push Shift Lever Button and Insert a small Allen Wrench Up under the Button from below.
● Press down on the Allen Wrench to Pry out the Shift Button
● Underneath the Button (once removed), you'll find a Spring and Clip. Remove these (noting the orientation of the Spring) and lift off Shift Knob.
● Using a Plastic Pry Tool (or carefully using a Screwdriver) insert under the Base of the Shift Plate and Pry this off.
● Install New Shift Plate by snapping it into position
● Install New Shift Knob and reattach Spring and Spring Clip (again orienting it as before)
● Snap Shift Button back in place on New Shift Knob.
You're done - Total Time: 5 min. Hope this helps...
Happy Motoring!... Jim'99
Old 01-15-2006, 03:01 PM   #3
Thanks for the instructions
Thanks for this. Worked like a charm and always better than going to the dealership.
I found this octagonish black plastic piece that has a spring attached to it when I lifted the shift plate up. I only hope that it fit back into place as it should when I put the new shift plate back on.....
Everything seems to shift fine so I guess I didn't screw anything thing up....
What is the plastic piece with the spring in it anyway, and which way is it really suppose to face?
Jimmy
Old 01-15-2006, 03:08 PM   #4
Jimmy
Hi,
That's just a Spring Seat, if you reinstalled it like before... you're OK - Good Job!!
