07-18-2013, 06:47 AM
2001 Boxster S
Carrera lights wheel question
Sorry for another wheel question but just wanted to get a second opinion...
Wheels are front 8" with 57 offset and 10" with 58 offset. Would these fit my 2001 S? Tried the wheel calculator and it appears the rears would require an extensive spacer. Not quite sure that's a good idea.
Wheel experts your comments please!
2001 Boxster S
Arctic Silver
'Brenda' aka Money Trap aka 100% Fun!
07-18-2013, 07:23 AM
If your goal is to achieve both fitment and appearance, then you'll need to lower the fronts and rears by about 15mm's.
07-18-2013, 07:30 AM
Fronts : 8 to 8.5 inches wide with offsets ranging from +35 to +45 depending on how aggressive you want to go.
Rears: 9 to 10 inches wide with offsets ranging from +35 to +45 depending on how aggressive you want to go .
Don't care......was made to care! (my Mum)
07-18-2013, 07:31 AM
now that is a direct JD quote!
07-18-2013, 08:34 AM
I'm impressed !
07-18-2013, 08:38 AM
2001 Boxster S
Thanks, gents.
Reading thru some previous posts, it seems a 15/20 spacer setup would give a flush look.
Not a big fan of spacers probably because I don't know much about their impact. But if JD uses them, it should be okay.
Now, to find out about the quality of the wheels being offered...
2001 Boxster S
Arctic Silver
07-18-2013, 08:48 AM
Originally Posted by Dgnarvs
Thanks, gents.
There's nothing wrong with the use of spacers is this application, provided they are guaranteed to be hubcentric.
07-18-2013, 09:24 AM
BTW these are the carrera lights for 996s... Porsche makes them in boxster fitment 7.5" front & 9" rear that do not require spacers at all.
07-18-2013, 03:17 PM
2001 Boxster S
I suppose so. I just haven't found a set at the right price range.
Going for the Boxster fitment also means there is no added aggressiveness to the look! Hmmm...
2001 Boxster S
Arctic Silver
07-18-2013, 04:44 PM
Just follow the formula for lowering the offset via spacers and you'll be all set.
07-19-2013, 01:25 AM
and remember..... anything above 3MM spacers will require a longer lug bolt - add the wdith of the spacer to the length of the OEM bolt and purchase replacements accordingly.
07-19-2013, 05:39 AM
Is there an echo here ?
07-19-2013, 05:45 AM
Ha Ha, that day you got banned had us all running scared - so i thought best to brush up in case we needed a new 'Grand Poobah' for such info.
Luckily for us you are still with us, but now i have knowledge and i just wanna use it!
07-19-2013, 06:36 AM
Whoa! I must of missed something... Anyone know where I can go to find out what happened and why JD got banned? If he can get banned; no one is safe.
07-19-2013, 06:45 AM
look up Threads by @ Farewell Danger
The story plays out!
07-19-2013, 07:36 AM
2001 Boxster S
Thanks, JD! Any suggestion on which brand and how much I should budget for 15/20 spacers? Are those being sold by Suncoast any good?
2001 Boxster S
Arctic Silver
07-19-2013, 08:12 AM
There are a million and one suppliers for spacers. I have H&R, try ecstuning.com that's where I got my spacers and bolts
07-20-2013, 10:28 AM
... then one day, Johnny Danger began thinking he was a GOD!... and so the thunder did rain down, oh so soon!...
07-20-2013, 10:37 AM
Don't forget the part about the frogs and locusts !
07-20-2013, 10:42 AM
Nor that the frog turned out to be a prince!
