Old 07-18-2013, 07:47 AM   #1
2001 Boxster S
Carrera lights wheel question
Sorry for another wheel question but just wanted to get a second opinion...
Wheels are front 8" with 57 offset and 10" with 58 offset. Would these fit my 2001 S? Tried the wheel calculator and it appears the rears would require an extensive spacer. Not quite sure that's a good idea.
Wheel experts your comments please!
2001 Boxster S
Arctic Silver
'Brenda' aka Money Trap aka 100% Fun!
Dgnarvs is offline   Reply With Quote
Old 07-18-2013, 08:23 AM   #2
Johnny Danger's Avatar
If your goal is to achieve both fitment and appearance, then you'll need to lower the fronts and rears by about 15mm's.
Old 07-18-2013, 08:30 AM   #3
EssexPorsche's Avatar
Fronts : 8 to 8.5 inches wide with offsets ranging from +35 to +45 depending on how aggressive you want to go.
Rears: 9 to 10 inches wide with offsets ranging from +35 to +45 depending on how aggressive you want to go .
Don't care......was made to care! (my Mum)
EssexPorsche is offline   Reply With Quote
Old 07-18-2013, 08:31 AM   #4
now that is a direct JD quote!
Old 07-18-2013, 09:34 AM   #5
I'm impressed !
Old 07-18-2013, 09:38 AM   #6
2001 Boxster S
Thanks, gents.
Reading thru some previous posts, it seems a 15/20 spacer setup would give a flush look.
Not a big fan of spacers probably because I don't know much about their impact. But if JD uses them, it should be okay.
Now, to find out about the quality of the wheels being offered...
2001 Boxster S
Arctic Silver
Old 07-18-2013, 09:48 AM   #7
Originally Posted by Dgnarvs View Post
Thanks, gents.
There's nothing wrong with the use of spacers is this application, provided they are guaranteed to be hubcentric.
Old 07-18-2013, 10:24 AM   #8
BTW these are the carrera lights for 996s... Porsche makes them in boxster fitment 7.5" front & 9" rear that do not require spacers at all.
Old 07-18-2013, 04:17 PM   #9
2001 Boxster S
I suppose so. I just haven't found a set at the right price range.
Going for the Boxster fitment also means there is no added aggressiveness to the look! Hmmm...
2001 Boxster S
Arctic Silver
Old 07-18-2013, 05:44 PM   #10
Just follow the formula for lowering the offset via spacers and you'll be all set.
Old 07-19-2013, 02:25 AM   #11
and remember..... anything above 3MM spacers will require a longer lug bolt - add the wdith of the spacer to the length of the OEM bolt and purchase replacements accordingly.
Old 07-19-2013, 06:39 AM   #12
Is there an echo here ?
Old 07-19-2013, 06:45 AM   #13
Ha Ha, that day you got banned had us all running scared - so i thought best to brush up in case we needed a new 'Grand Poobah' for such info.
Luckily for us you are still with us, but now i have knowledge and i just wanna use it!
Old 07-19-2013, 07:36 AM   #14
Whoa! I must of missed something... Anyone know where I can go to find out what happened and why JD got banned? If he can get banned; no one is safe.
Old 07-19-2013, 07:45 AM   #15
look up Threads by @ Farewell Danger
The story plays out!
Old 07-19-2013, 08:36 AM   #16
2001 Boxster S
Thanks, JD! Any suggestion on which brand and how much I should budget for 15/20 spacers? Are those being sold by Suncoast any good?
2001 Boxster S
Arctic Silver
Old 07-19-2013, 09:12 AM   #17
aclark133's Avatar
There are a million and one suppliers for spacers. I have H&R, try ecstuning.com that's where I got my spacers and bolts
aclark133 is offline   Reply With Quote
Old 07-20-2013, 11:28 AM   #18
woodsman's Avatar
... then one day, Johnny Danger began thinking he was a GOD!... and so the thunder did rain down, oh so soon!...
Old 07-20-2013, 11:37 AM   #19
Don't forget the part about the frogs and locusts !
Old 07-20-2013, 11:42 AM   #20
woodsman's Avatar
Nor that the frog turned out to be a prince!
