Old 06-26-2013, 10:25 PM   #1
Just a Swede
The original PSE
I have found a used PSE from 98, is just to bolt it on the car or is there vacuum lines like the ones on the newer models?
smygolf is offline   Reply With Quote
Old 06-27-2013, 03:05 AM   #2
Some of the early cars had smaller diameter pipes than the later cars, so make sure it is going to fit your car. The vacuum system operates the system that quiets the car down, the default setting (no vacuum) is loud, so you don't really need to connect it.
Old 06-27-2013, 08:35 AM   #3
Just a Swede
Thanks for the info!
I talked to the delar today and they only have the muffler part inc the vacuum vents.
So im searching for the parts i need.
The muffler it self is pretty cheap so mayby i stick with that .)
Old 06-27-2013, 11:49 AM   #4
Just a Swede
Anybody who have some info/pics on the controler thats producing vacuum?
Old 06-27-2013, 12:05 PM   #5
It uses engine vacuum routed through a control unit that measures the car's speed.................
Old 06-27-2013, 12:09 PM   #6
The Radium King's Avatar
you could probably use the same mechanism and control signal as used by the resonance flapper on the intake to control a cutout on the exhaust - over 4000 rpm the cutout opens and bypasses the muffler. you would need to confirm that it could take the heat, need one on each side, and mebbe get a bigger vacuum tank to address the larger load.
Old 06-27-2013, 12:09 PM   #7
Just a Swede
Aha,
There was a PSE for sale at ebay.de that i missed.
Anyway there is some pics on the vacuum lines and a relay
So those parts is the parts im missing.
www.ebay.de/itm/Porsche-Boxster-986-Auspuff-Klappenauspuff-Original-2-7-3-2-99611198700-/160930856560 - Translator
Thanks Jeff!!!
*edit*
Radium,
I found a German dealer thats sells different exhaust with vacuumvalves, with a bit of luck i can get te Control unit there.
Tanks for the info!!
Old 06-27-2013, 01:34 PM   #8
Got to be careful about how you rig this up, several European countries have noise limits (in dB) at certain speed levels (KPH or MPH) that the system has to comply with to pass their version of inspection. To my knowledge, Switzerland is the worst in this department, and that was the benchmark the PSE with all the electronics and vacuum hook ups was designed to pass.
Old 06-27-2013, 04:35 PM   #9
You could always buy the Pse box and turn it on and off remotely with an aftermarket key fob .....
Ian c is offline   Reply With Quote
Old 06-27-2013, 08:20 PM   #10
Just a Swede
I did not know that you still could buy the box.
With a bit of luck Albert Motorsport has the parts i need.
Porsche 986 Boxster Auspuff - Albert - Motorsport UG
Old 06-28-2013, 05:05 AM   #11
Try gert at carnewal in Belgium ..
Old 06-28-2013, 01:23 PM   #12
Just a Swede
Thanks Ian, found some goddies there!
Old 06-29-2013, 05:38 AM   #13
You're welcome !!!
Gert is a good guy .
Helped me out with lots of porsche parts over the years
Old 06-29-2013, 05:51 AM   #14
Just a Swede
I asume that the remote version is just as the original PSE?
Old 06-29-2013, 06:13 AM   #15
Key fob remote , rather like an aftermarket alarm .
Old 06-29-2013, 07:45 AM   #16
Just a Swede
I see,
So if i want the 4000 rpm function i have to go with Porsches original parts.
They got mail to but i suspect its gonna cost Alot!!
Thanks again Ian, much appreciated!!
Old 06-29-2013, 08:18 AM   #17
Originally Posted by smygolf View Post
I see,
No, the OEM system shuts the bypass valves (via vacuum), and prevents them from opening, between speeds of 17 and 29 MPH to meet the Swiss legal sound standards................
Old 06-29-2013, 08:39 AM   #18
Just a Swede
Never ending knowledge )
In that case user operated is way better.
Is there any possibility to incorporate the 4000 rpm function?
Old 06-29-2013, 02:33 PM   #19
You would have to fabricate the associated electronics for that to happen.
Old 06-29-2013, 04:12 PM   #20
The speed control takes its command signal from the Ecu on my car and im presuming its the same on the boxster .
Most people want to get rid of it , not incorporate it !!!
But I'm thinking you have everything there allreAdy in the car to get hour signal and it would be a simple wiring job to make it happen with maybe a relay at worst .
Ill look into my 997 Pse data sometime for you
