Old 01-02-2006, 08:34 AM   #1
Cold Start Question
Dear Boxster Owners
I experience an dry metal noise for a first second, then the engine is cold started. Does it happens because of luck of oil, or oil is completely goes down. How to solve this problem. I changed recently to 10w30, because of the winter cold weather here and toward the winter naps. What will be your sugesstions?
thank you and happy new 2-98-6 year.
98 Porsche Boxster Red 55k
90 Toyota Camry Grey 229K
96 BMW Z3 80k
Porschev is offline   Reply With Quote
Old 01-02-2006, 09:01 AM   #2
I had that for the first time after the car sat for about 2 weeks and the weather here turned cold. It was very disconcerting but I don't see any way around it since we can't pre-charge the oiling system. The best we can hope for is that synthetic leaves enough of a layer that the noise isn't the result of too much wear and tear.
Cogito Ergo Zoom!
I Think, therefore I go fast
Current Porsches:
2004 Cayenne Turbo
2003 Boxster S
Past Porsches:
1989 911 turbo
1981 911SC
1984 944
1973 914
mjw930 is offline   Reply With Quote
Old 01-02-2006, 09:42 AM   #3
Brucelee's Avatar
You should use Mobil 1 0W-40 in your Boxster.
10W30 is actually harder on the car at startup.
The noise is normal, not to worry!
Rich Belloff
Old 01-02-2006, 10:53 AM   #4
Thank you very much
Thank you Brucelee and Mjw930
I will change oil immediately
96 BMW Z3 80k
Old 01-02-2006, 11:33 AM   #5
bmussatti
Posts: n/a
Porschev, yes, Brucelee is correct. You should run the Mobil 1 0W40 year round. The 0W40 will be much better upon cold weather start-ups vs. the 10W30. It will flow better/faster and possibly eliminate that metal sound.
Old 01-02-2006, 12:24 PM   #6
Brucelee's Avatar
Good luck with your BOX!
Rich Belloff
