Old 06-10-2013, 05:11 PM   #21
Need For Speed
KRAM36's Avatar
Yes.
the driver side, is an intake to the air filter.
the passenger side, is an outlet. behind it, there is an electric fan, that will blow air out, when the temperature at engine compartment gets to a certain value (can't remember the value at the moment).
About the passenger side blowing out. I've checked this several times with a piece of paper and on my 2003 S it pulls air in, as the paper sticks to the vent.
Old 06-11-2013, 12:16 PM   #22
woodsman's Avatar
that's strange but maybe there's always a little vaccume there???? I've driven my car 2 summers (including falls) and have only heard that fan on a few times each year.
Old 06-11-2013, 12:17 PM   #23
Guvs's Avatar
Mine is a 03 facelift 986 Right hand drive and my near side (passenger’s side) air vent is defiantly a different shape, it has a defeat quarter inch lip that sticks out from the body of the car.
Where as the off side (driver’s side) is flush fitting and doesn’t stick out, and it is not because of a bad fit they are a different shape/design.
Guvs.
Guvs is offline   Reply With Quote
Old 06-12-2013, 01:30 PM   #24
Guvs.
if you take out the drivers side scoop and look at the back side, you'll see a small L shaped piece that is raised from the service. that piece need to go behind the lip in the scoop pocket. i didn't know that and broke mine off when i put it back in. now it's flush, but moves a little.
cameronzero is offline   Reply With Quote
Old 06-12-2013, 01:43 PM   #25
Old 06-25-2013, 07:28 PM   #26
I like those black rims how di you do it? are those plasti dip?
pedot99boxster is offline   Reply With Quote
Old 06-25-2013, 07:40 PM   #27
Yes. Plasti-dip is your friend
