Old 06-05-2013, 11:10 AM   #1
Boxster misfire
Hi all,
My 2002 2.7 misfires when setting off from standing and wont puul away smoothly in a high gear without misfiring. The engine check light sometimes flashes and sometimes lights continuously for a few seconds.
The problem seems less severe when the engine is cold, I think!
Any ideas anyone?
13JB is offline   Reply With Quote
Old 06-05-2013, 12:08 PM   #2
Originally Posted by 13JB View Post
Hi all,
Any ideas anyone?
What are the codes?
Have them checked and reply back with them.
Could be a number of things from bad plugs, bad cap, to cracked cylinder walls.
Good luck
SF-Rockster is offline   Reply With Quote
Old 06-05-2013, 12:27 PM   #3
Thanks, I am told the codes wont show up unless the engine light is constantly lit?
Old 06-05-2013, 12:39 PM   #4
Moderator
Codes should still show up. If you are lacking a code reader you can borrow one from an autoparts store.
Old 06-05-2013, 12:41 PM   #5
BYprodriver's Avatar
Sounds like possible bad fuel pump or intermittent crank position sensor.
Old 06-05-2013, 12:57 PM   #6
Bmod986's Avatar
Could also be the coil packs.
Bmod986 is offline   Reply With Quote
Old 06-05-2013, 01:24 PM   #7
The Radium King's Avatar
flashing light is bad - don't drive the car.
