Old 06-04-2013, 05:57 PM   #1
Joining the insanity
Ok, I've had my '00S with a build date of 05/00 on the door stamp in the air for an hour now. I've searched and cannot find where the engine vin is located. If it's viewed from the top looking down (I have the car in the air) please be kind.
thanks!
sean
Old 06-04-2013, 06:07 PM   #2
still plays with cars...
BoxsterSteve's Avatar
Look around above the sump plate. It's stamped there.
Six speed 2000 Boxster S
Old 06-04-2013, 06:19 PM   #3
I did and I'm not seeing it??? It's driving me nutso! Your talking about the plate that the oil drain plug goes into right???
Old 06-04-2013, 06:20 PM   #4
also, is it one the ds or pass side?
Old 06-04-2013, 06:28 PM   #5
rp17's Avatar
I recall mine being on the passenger side. Had to clean it off to really see it. Passenger side facing outward on the sumplate IIRC.
Old 06-04-2013, 06:29 PM   #6
The Radium King's Avatar
passenger side, near the back of the sump (the flat plate that the oil plug goes into). it is beveled and probably so covered in crud that you can't see the number.
in the main image below, look at the top of the right side of the sump - you'll see beveled metal bit sticking out the side of the block - vin number on that:
http://www.pelicanparts.com/techarticles/Boxster_Tech/12-ENGINE-deep_sump/images_med/Pic1.jpg
*** beaten by the quick trigger finger of rp17!
Old 06-04-2013, 06:42 PM   #7
Got it!!! I've looked at it a 1000 times tonight! I've been cleaning on it with a stiff brush and degreaser and I still can't read it! I can make out the m96 but can't read any of the other numbers/letters :-(
Old 06-04-2013, 06:48 PM   #8
Success!!! For what it's worth. It was just really dirty.
M96/2167Y08948
Does that mean anything to anyone? Thanks for the quick replies you guys!
Old 06-04-2013, 07:18 PM   #9
kjc2050's Avatar
It means your engine was built in 2000, and likely has a double row IMSB.
Per the Pelican article on IMSB replacement:
Up to engine # M 671 11237 Boxster S 3.2L M96.21 Double Row Bearing
