Old 05-30-2013, 12:56 PM   #1
oil return valve?
Someone I know has been told by a mechanic that the 2.7 he has been looking at will soon require an 'oil return valve' that will necessitate the removal of the engine and about 11 hours of labour. Does anyone have any idea what he is talking about? Yes, there are oil return tubes (that should not require engine removal). Yes, there is the AOS which has sort of a valve (actually, a diaphragm) - replacement of it also does not require the removal of the engine. There are PCV's - and again, no engine removal required. Am I missing something, or is he 'getting the gears', so to speak?
Brad
southernstar is offline   Reply With Quote
Old 05-30-2013, 02:02 PM   #2
Make sure he is not talking about the scavenging units in the cylinder heads.
Old 05-30-2013, 02:52 PM   #3
1999 base
Meir's Avatar
still doesn't require removal of the engine, if i remember correctly.
