Old 06-30-2017, 06:57 AM   #1
Yes sir, I realize the numbers may be a bit off. I'm not dropping the tranny until it's required, either by sufficient evidence I have a single row or the clutch needs replaced.
I can get the engine ID if it'll help my quest for more info.
Dillier23 is offline   Reply With Quote
Old 06-30-2017, 09:27 AM   #2
VIN list are more than a bit off, they are useless in determining what style IMS bearings are in the 2000-2001 cars. We have seen very early 2000 cars with single rows in them, and some of the last 2001 engines built with dual rows in them.
The only way to know which one is in there is to take it apart and look.
Old 06-30-2017, 01:04 PM   #3
I think I've dug enough to find enough evidence to have at least 95% accuracy that mine is a Double Row bearing car. Engine number and serial number are both outside the ranges given by Pelican Parts and the verbiage in the IMS lawsuit.
Thanks for you help, I feel much better about this car!
Old 06-30-2017, 01:37 PM   #4
Both of which have been proven wrong over and over again. We just put an IMS Solution in a 2001 that according to your logic should have been a double row car. It wasn't.
Old 06-30-2017, 03:22 PM   #5
Well JFP, I suppose I'll let it go until the clutch needs replaced. In the meantime I'll cross my fingers.
Old 07-03-2017, 04:18 AM   #6
sfkjeld's Avatar
Same with me. VIN showed double row. Reality was single. Really is only one way to know.
sfkjeld is offline   Reply With Quote
Tags
ims lawsuit 2000 2001
