Old 05-19-2013, 11:26 AM   #1
mcomet's Avatar
EBrake sensor off and top wont go up?
I think something happened with my emergency ebrake sensor as it is not illuminating and the top wont function...any ideas?
Comet
Michael Comet - www.comet-cartoons.com
2014 Guards Red Cayman S - PSE - PASM - 20"CC - INFTMT - CONV - etc..etc...
SOLD - 2003 Speed Yellow Porsche Boxster S - LNE IMS - Klisstle Rollbar Cover
mcomet is offline   Reply With Quote
Old 05-19-2013, 11:54 AM   #2
woodsman's Avatar
I think there's a sensor under the arm you pull on. I saw it when I removed my center console cover. It could be a fuse too
Old 05-19-2013, 11:56 AM   #3
mcomet's Avatar
Yeah I found a old thread linked to this. Seems useful. Anyone know what fuse so I can check?
Boxster Projects | Parking Brake Sensor Switch
Old 05-19-2013, 11:57 AM   #4
Comet
Likely the switch on the ebrake. You'll need to pull the access panel on the center console for the brake and have a look. Not a biggee, take your time. The panel is pried away at the top and then pulls up and out. This should give you access to the ebrake sensor (it's a button switch) inside the console...
shadrach74 is offline   Reply With Quote
Old 05-19-2013, 04:29 PM   #5
DIY extremist
black_box's Avatar
I had this problem with my 986 when I first got it. There is a little white plastic encased microswitch that sets the e-brake light. It's about $6, or you can use electrical contact cleaner on it.
You can jury-rig your way around a malfunctioning one the way I did (with no tools needed) so I could just get the top to operate:
From memory, on the driver's side of the E-brake you can yank on the plastic piece that covers the mechanism. Then you should see the switch and a two prong plug stuck to it, pull the plug out, stick a piece of wire or a paperclip into it to close the circuit. Jam it in weel and it will stick. Put the plastic cover back on if you want. Voila, e-brake light stays on (but not the tail brake light) and you can operate top at your leisure. I cleaned out the switch and it's been fine since.
"Betty" -- 2000 Boxster S, Triple Black, loaded except PSM (sold to a good home)
"Veronica" -- 2008 Boxster S, Arctic Silver on Blue
"Maleficent" -- 2007 Cayman S, Red and Black, TPC Turbo 3.6L 460 RWHP, H&R RSS Coilover / TPC stage 2 suspension
black_box is offline   Reply With Quote
Old 05-25-2013, 10:36 AM   #6
mcomet's Avatar
Thanks all, I bought the proper replacement part from Pelican for $10 and replaced this morning... All good again, EBrake light works, top functions.
thanks
comet
Old 07-05-2013, 11:29 AM   #7
Just happened to me now
Haven't driven the car for 3 weeks.
Get in it and top won't go down.
Quickly jump on forums and do a search.
This is exactly my problem.
Pulled covers off driver side
U can see the white and black plug.
Pulled it out .sprayed some electric cleaner in in.
No tools needed
Done. Top works..less than 10 min 2 fix including searching this forum.
u guys r great... i am happy now
Good quick advice
Living one calculated risk @ a time
chris97boxster is offline   Reply With Quote
