Old 05-18-2013, 04:01 PM   #1
kjc2050's Avatar
Gas Cap Tether: installed correctly?
My car came with a gas cap w/o the strap or tether. I bought a new cap and the required rivet from Pelican, but then wasn't sure how to properly install it. Yeah, I know, insane. Anyway, is this correct? --
Old 05-18-2013, 06:03 PM   #2
Beelzy's Avatar
Looks like it's correct. However, my rivet mounts in a different spot. (2004 base)
Beelzy is offline   Reply With Quote
Old 05-19-2013, 06:42 AM   #3
INCORRECT.
The rivet is in the wrong hole.
If you post a pic that shows more, I can point out the proper mounting hole.
seventythree is offline   Reply With Quote
Old 05-19-2013, 12:51 PM   #4
kjc2050's Avatar
Originally Posted by seventythree View Post
INCORRECT.
Thanks. Take your pick:
Old 05-19-2013, 02:58 PM   #5
Found this on Pelican Parts blog, showing the correctly position.
grtc68 is offline   Reply With Quote
Old 05-19-2013, 03:14 PM   #6
THe other option, if your MY doesn't have that hole:
Old 05-19-2013, 03:22 PM   #7
That's it. Here is how it looks on my 2002:
Old 05-19-2013, 04:17 PM   #8
kjc2050's Avatar
Thanks! Unfortunately, my car doesn't have a hole in the location shown above. I guess I'll just leave it as is. Thx again.
Old 05-19-2013, 04:50 PM   #9
Mine is set up exactly as yours is, as long as it works - problem solved.
Old 05-20-2013, 10:00 AM   #10
tanque55's Avatar
Has anyone had to change the locking mechanism on the gas fill door? Mine doesn't lock when I lock the doors like it's supposed to. Haven't seen the part anywhere and don't know how hard it would be to change.
tanque55 is offline   Reply With Quote
Old 05-20-2013, 03:52 PM   #11
I had the same problem with my 1999. When I put the rivet in the hole under the clip, the lid wouldn't close. I then used a flat head bolt and nut in the same hole and the problem was solved. I like the solution grtc68 used. I was wondering what that screw to the left of the gas cap was for? I think I'll switch to his solution.
springer123 is offline   Reply With Quote
Old 05-20-2013, 06:25 PM   #12
kjc2050's Avatar
Yeah, I ended up moving mine to that location. Works fine. Thanks all, esp grtc68!
