Old 05-13-2013, 05:27 AM   #1
Engine making a noise - again
3 months ago it started rattling 3 days after I bought it. Turned out to be the water pump. Now it's making a noise again. Any thoughts to what it could be? Here is the audio:
Boxster 3.2L Engine Noise - YouTube
PO said the idler pulley had been changed. Alternator has been rebuilt (bearings included). Clutch in or out does not make a difference.
Thanks.
Old 05-13-2013, 06:29 AM   #2
Jager's Avatar
Does the sound change pitch when RPM's increase? Have you tried running the motor without the belt to see if the noise goes away?
Jäger
300K Mile Club
Old 05-13-2013, 03:05 PM   #3
Found the problem. A bolt from said water pump change came loose and was rubbing against the belt. In the 2nd photo you can see the belt grindings. A shop changed the pump - so this is their error.
Old 05-13-2013, 03:41 PM   #4
Damn Yankee
TeamOxford's Avatar
Originally Posted by patssle View Post
Found the problem. A bolt from said water pump change came loose.
WTF?
Old 05-13-2013, 04:16 PM   #5
WTF?
Does that sound like BS? (genuine question)
My dad suspects it may have been like that.
1. The bolt won't screw back on - it seems snug (I didn't try to loosen it though).
2. If it was loose, why is the belt rubbing in 1 exact spot - wouldn't the bolt be turning?
So either it was cross threaded, some dirt is preventing it from screwing back on, it's too long of a bolt, or it is loose.
Any thoughts on this? (the belt is loosened in this photo)
