Old 05-10-2013, 05:35 PM   #1
notworthy's Avatar
Turned my ignition, nothing then a whirring noise from the back - what happened?
Hey all,
I need some technical help please. I turned the key on my boxster (2003 2.7) for a normal start and it didn't start or tick over however a whirring noise from the back went into action and stayed on for about 30 seconds (felt like a minute). During that whirring noise time I had turned off the ignition and had the key pulled out.
Has anyone experienced this before and/or have an idea of what just happened.
The noise was still going even with the key out of the ignition!
I waited until the noise stopped, turned the ignition again and it started really abruptly (almost perfectly) and no issue at all. Really strange.
Thanks, I look forward to your responses.
notworthy is offline   Reply With Quote
Old 05-10-2013, 05:42 PM   #2
Sticky or failing starter solenoid
Rebuild or replace soon or you'll be paying for a tow.
Old 05-10-2013, 07:09 PM   #3
notworthy's Avatar
Thanks for your input. So, does this mean replacing the whole starter motor or is there another option?
Old 05-10-2013, 07:43 PM   #4
Porsche "Purist"
Paul's Avatar
Clean and lube the solenoid and bendix and take your chances.
1987 924S. 2002 996TT. PST-2
Old 05-10-2013, 08:15 PM   #5
BYprodriver's Avatar
Could be the ignition switch going bad
Old 05-10-2013, 08:46 PM   #6
Personally, I'd just disassemble and clean the solenoid and lube the bendix, as Paul said.
Old 05-17-2013, 03:59 AM   #7
notworthy's Avatar
Thanks for your comments. It has been 6 days and not a sign of it happening again. Prevention is better than a cure though. I have never done this before and am brave enough to have a look at tackling this. Any pointers?
Old 05-17-2013, 11:06 AM   #8
woodsman's Avatar
buy a good manual first- I have a Bentley and it seems to skip a lot of details.
