Old 01-25-2018, 11:27 PM   #581
MAD
MAD MIKE
Hey guys no luck finding my code? any help is greatly appreciated
1998 Porsche Boxster 986
CDR 220/210?
Serial#: W5020299
R 3297
MAD is offline   Reply With Quote
Old 02-03-2018, 04:56 AM   #582
Heiko's Avatar
CDR 220/210?
Serial#: W5020299
R 3297
Try 6729 or 6728 in that order....
Heiko
Previously owned:
Old 03-19-2018, 04:17 PM   #583
I also now need a code for a recent alternator replacement. Where can I find the serial # that everyone is listing?
Rob
2017 Audi SQ5
2012 Mercedes C63
2001 Boxter S
Lebby83 is offline   Reply With Quote
Old 03-20-2018, 03:21 AM   #584
Heiko's Avatar
The hard way is to pull out the radio unit if you have the release keys for the slots
The easier way is to do this.....
Turn off radio.
Hold down the TP button for at least 10 seconds.
Turn the radio on. "Becker 1" will be displayed.
Rotate the right knob slowly, as it will display the Becker model number.
Rotate again and radio serial number will display on radio display.
Heiko
https://greatcyclechallenge.ca/Riders/HeikoVoss
Previously owned:
Old 03-20-2018, 05:12 AM   #585
Turn off radio.
Heiko
Thank you! This is what I got..
Serial # Y5024058
Type 4362
It also has 24/99 on one of the screens.
Is there someone on here that can use that to get me a code?
Also when I turn on the radio, at least last night, it states "wait" - Where does it ask you for the code? Any help appreciated!
Thanks, Rob
Rob
2017 Audi SQ5
2012 Mercedes C63
2001 Boxter S
Old 03-21-2018, 04:39 AM   #586
Heiko's Avatar
Serial # Y5024058
Type 4362
Thanks, Rob
In that case try 9889 and if that fails try 8887
cheers
Heiko
Previously owned:
Old 03-21-2018, 06:03 AM   #587
cheers
Heiko
Thanks. Will give it a shot later.
Rob
2017 Audi SQ5
2012 Mercedes C63
2001 Boxter S
Old 04-08-2018, 09:35 PM   #588
2002 Boxter CDR 220 need radio code
Hi I'm looking for a radio code for my 2002 Boxster ser# 25013981. Any help would be very much appreciated.
harrison74 is offline   Reply With Quote
Old 04-11-2018, 04:52 AM   #589
Heiko's Avatar
I also replied to your PM
Try 4689 first and if that doesn't work try 4687
Cheers
Heiko
Previously owned:
Old 04-11-2018, 09:08 PM   #590
Radio code reset-- WAIT code not going away
I have a 99 Boxster base model. I had to disconnect the battery so I did the trick to find the radio code-
-Turn off radio.
-Hold down the TP button for at least 10 seconds.
-Turn the radio on. "Becker 1" will be displayed.-
-Rotate the right knob slowly, as it will display the Becker model number.
-Rotate again and radio serial number will display on radio display.took pictures
Going through the cycle with the right knob, it showed me:
BECKER 1
TYPE 4462
SER: X5021117
48/98
GAL: 00
AUX OFF
CDP2081
After reconnecting the battery, I turned on the radio and it told me to enter the code, so I entered 4898. Then the readout said WAIT and still did, after leaving it for 10 minutes, driving it, turning it off and on again, etc. Then I looked under the frunk and saw handwritten on the paper sticker "Radio 5430." Couldn't figure out how to re-enter a code, so I disconnected the battery for half an hour, and when I reconnected the battery, the readout still said WAIT. Drove it for 80 or 90 minutes, and the WAIT never went away. Loren said you have to wait 30 minutes before trying again, but will it prompt me to re-enter a code, or is there a way for me to override the WAIT?
MikeMcMo is offline   Reply With Quote
Old 04-12-2018, 11:36 AM   #591
-Turn off radio.
BECKER 1
TYPE 4462
SER: X5021117
48/98
GAL: 00
AUX OFF
CDP2081
DISREGARD! The problem resolved itself. I took a 30 minute drive, and it persisted, then the car sat an hour, and after a 20 minute drive it was ready to take the handwritten frunk code.
Since 48/98 wasn't the code, can anybody tell me what that and the other bits of information on the display were:
48/98
GAL: 00
AUX OFF
CDP2081
Old 04-12-2018, 03:29 PM   #592
I have a 996 Turbo (2002) with a Cdr 22 with
Model Number: BE 4467
Serial Number: Y5027469
Can you find the radio code. This would be very nice and i will be very greatful for your help...
Thank you so much and have a good night.
LDausE is offline   Reply With Quote
Old 04-13-2018, 07:58 PM   #593
Heiko's Avatar
48/98
GAL: 00
AUX OFF
CDP2081
According to your serial the code should be either 4430 or 4330 (try 4430 1st)
Heiko
Previously owned:
Old 04-13-2018, 08:00 PM   #594
Heiko's Avatar
Originally Posted by LDausE View Post
Try 7263 first and if that doesn't work try 7262
Cheers
Heiko
Previously owned:
Old 04-14-2018, 10:39 AM   #595
Resolved
Heiko
Thanks. Perhaps that was the original. This car has a slightly confusing history, with seats, ignition key, entry keys, and radio taken out and put back in early on, so it might not be the original radio. (I looked under the frunk and saw handwritten on the paper sticker "Radio 5430.")
Old 04-18-2018, 05:10 AM   #596
The code was working perfectly. Thank you so much ))
Old 04-18-2018, 07:35 AM   #597
Heiko's Avatar
You're very welcome - Enjoy
Cheers
Heiko
Previously owned:
Old 04-30-2018, 10:29 AM   #598
Help radio code
Hi all, I just purchased a 1999 Boxster with the radio in **** mode.
The radio details are
Before
Ser X5016 340
Type 4467
49/98
Gall 00
Aux. Off
Becker cdr -22
I tried some codes listed here but so far no luck
Any help is greatly appreciated
Gauci is offline   Reply With Quote
Old 04-30-2018, 11:43 AM   #599
Heiko's Avatar
Before
Ser X5016 340
Type 4467
49/98
Gall 00
Aux. Off
Becker cdr -22
Trying codes list here are specific to the radio's Serial so that wont work.
Try 2837 and if that doesn't work try 2836
Heiko
Previously owned:
Old 04-30-2018, 01:59 PM   #600
Heiko
Thanks a million Heiko. Will try first thing in morning and let you know.
Thanks again from Malta
